![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
fuel pump
does this look like a real new pump for the 1.5?? seems cheap....
http://www.ebay.com/itm/Fuel-Pump-St...-/231051671953 |
That is the correct one. The OEM one is made by Denso, so that Aisan is an aftermarket one.
Mr. 155 and climbing
just curious....why do you think that you need a new fuel pump? aren't you also the chap looking to do a motor/trans swap as well? if so then it sounds like you have a lot of work you are putting into the car for sure.
just buying a little time... my hatch has no power on acceleration (good at idle)unless I pump the pedal.
I cleaned the entire fuel system except the pump and filter in the tank. I put in new injectors,cleaned throttle ,all other stuff and OCV too. If it isnt the pump/regulator at 400K miles, then its the computer. the engine swap is going to take some organizing and time. |
#5 | |
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
| 2007 sedan fuel pump not running and check engine light | nitrus10032 | DIY / Maintenance / Service | 23 | 08-23-2025 12:09 PM |
| Fuel Pump Failure | eaglerox | DIY / Maintenance / Service | 14 | 03-02-2013 10:27 AM |
| Fuel filter or Fuel pump :( | tyrone_yaris | DIY / Maintenance / Service | 2 | 05-08-2012 01:32 AM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
