![]() Drives: Yaris Sedan Join Date: Jul 2009
Hello folks,
I'm from Latin America and I need to know What I need to do when I reach 50k mi (80000kms) with my 2007 Yaris Sedan? what I need to check or change in my car? ![]() Please help me with this, I love my car and I want it perfect... ![]() Thanks dudes... |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
maintenance
well, aside form the regular maintenance like oil and air filter you might want to remove the spark plugs and check the gap, put anti-seize on the threads and put back in. Also check the control arm bolts that are a common problem of rusting . There is a diy thread around here just do a search. I took mine out a month ago and they were still in good condition and hardly any rust on the bolts.
You shouldn't gap the iridium plugs.
Perfect...
Well I have K&N air filter, I will clean my filter and put it again, so iridium plugs are better than OEM plugs??. Thanks again dudes... Best regards... |
![]() ![]() Drives: Want a yaris Join Date: May 2012
Just give it a good bath and make sure the oil changes are regular.
Of course, I have another question about the motor oil:
20w50 Valvoline Semi-Sintec 15w40 Shell Helix Semi-Sintec Or Castrol 20w50 Magnatec Semi-Sintec Which of this three oil are better? Remember is for my 1.5 vvt-i Yaris Sedan with 50K miles (80k kms). Thanks dudes... Happy thanksgiving to all ToyoFans!! |
#7 | |
oil
Depends where you live I believe. If where you live is mostly cold and stays below freezing for weeks on end ......ie Canada than synthetic oils will be best to use. If you live in a place where it's mostly warm and it only freezes once or twice a year but it's mostly above freezing temperatures year round than regular dino oil will be fine. I use Valvoline 5w30 regular dino oil |
#8 | |
jesus.. these oil are way too thick for the little engine. better go back to 5w30. |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Yes,the stated oil is too "heavy"....20w----. 5w-30,yes.
| Tags |
| 80k, kms, maintenance, miles, yaris 2007 |
| Maintenance schedule | Connoisseur_of_fine_cars | DIY / Maintenance / Service | 9 | 10-05-2011 08:46 PM |
| 4-wheel alignment for 5000 mi. maintenance????? | Yari-Chan | General Yaris / Vitz Discussion | 44 | 01-28-2011 10:00 PM |
| 60K Mile Maintenance | Pattycake | DIY / Maintenance / Service | 20 | 11-17-2009 03:34 PM |
| Question about required maintenance | gm830 | DIY / Maintenance / Service | 9 | 11-04-2008 04:14 PM |
