Old 01-15-2014, 09:54 AM   #1
Steveh27
Drives: 2010 3dr hatchback auto red
engine air filter
I read the post on cleaning the MAF sensor & bought that spray. When I bought it I thought about buying a new air filter as that's never been replaced. My manual does not give a part number, location, directions for replacement or any info regarding the air filter. I searched our forums & could not find anything here. Can anyone help?
Steveh27 is offline   Reply With Quote
Old 01-15-2014, 10:16 AM   #2
The filter housing is located right in front of the battery. There are two metal clips that you flip down to and then the other side of the cover is seated into a groove. Once you lift the cover the filter is right there. There is a square corner on the filter, note where that was positioned and orient the new one the same way.
As for part numbers, you can always check the book by the filters in the auto parts or big box store, but off the top of my head the Fram part is CA10190.
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Correct air filter not fitting right in sedan? JerseyJeff84 DIY / Maintenance / Service 13 09-28-2011 02:27 PM
Engine Air Filter Shadowbeast DIY / Maintenance / Service 7 06-16-2010 09:00 PM
