management/tuning on +/- stock car?
I'm wondering how much power could be extracted by throwing an eManage or V-manage or similar and tuning a stock or nearly stock N/A Yaris.
I know the factory tune is very conservative so there is room for a more aggressive map. Any thoughts on this idea? What if we could extract another 25hp out of it without changing hardware or going F/I?
AFAIK nobody's really done much in that respect, as the ECU is quite quick to counter any modifications that people may make to the A/F ratio mapping
the tein yaris (siphon mag, issue 002) made 106.1 whp and 104.4 ft/lbs with custom exhaust work, an intake and the camcon II. the camcon can adjust a/f, and the vvt-i.
http://www.powerenterpriseusa.net/pr...con/camcon.htm Last edited by fu_im_from_texas; 06-27-2007 at 09:27 AM. Reason: a/f correction |
37HSSV
ok, found prices and what it does.
All it seems to do is just electronically modifys the camshaft, without messing up the vvti. Also it 'Can' as stated on its site, to modify the air/fuel mixture. how much i cant tell. If you want to say a roundabout 106.1whp would be around the number were looking for in the 120 ballpark fwhp http://www.power-enterprise.co.jp/as...con/1NZ-FE.pdf This site only has a nice graph showing what exactly it does to the engine: Top is cam ratio. Bottom is Fuel/Air Mix, now how this relates to the stock, I dont know... will have to do a bit more reading. Price is ¥39,900 (its about $350USD) Harness looks like around ¥4,200($35) Shipping would be high, but if it works, good deal
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
46 and 2, just ahead...
Drives: 07 Yaris sedan Join Date: Jun 2007
Looks like you need to hack up your factory harnesses..risky business. I'd be inclined to either wait for a plug-n-play, or at least hold off until the factory warranty
37HSSV
Depends, looks like the Harness for the controler goes right into the ECU, maybe the ECU has an expansion port, or a Diagnostic port? wouldnt know.
ok, I'll do a little homework as well, and let's keep this thread open with any new info. thanks!
#8 | |
![]() ![]() Drives: '07 3 Door Yaris of Doom! Join Date: Dec 2006
Just email tech@cobbtuning.com and tell them to make an AccesPORT for the Yaris. That way you can have full plug and play tune-ability of the factory ECU(timing, fuel, VVTI, etc.), and no piggy back crap for the stock ECU to out learn. You can also use it as a tach!
#9 | |
You can set it to have the display screen be a gauge, and just about every signal the ECU receives can be displayed as a numeric number and analog gauge combination. RPM, vehicle speed, coolant temp, intake temp, etc.
The AccessPORT's features include: • On-the-fly map switching • Monitor vehicle sensor data and display in analog or digital format • Vibrant color graphic display with First-Ever full 260,000 color OLED, high resolution screen • Read/Clear engine trouble codes • Preloaded with performance, economy and convenience maps • Update via the Internet • Measure 0-60 and Ľ mile times • Adjustable on-screen Shift Light functionality • Estimates horsepower and torque • Displays current and averaged fuel economy • Drag race simulation with reaction time and “time slip” data • Built in on-screen help mode function • Multi-Language support • RoHS compliant (Lead Free design) • Custom performance tuning for your specific vehicle and modifications as provided by an authorized AccessPORT ProTUNER™ center, or upgrade to the StreetTUNER™ software package for do-it-yourself tuning. Call and talk to their tech support guys, I'm sure they would be more than willing to explain the functionality and features of the AccessPORT to you: 801.713.0035
#11 | |
#12 | |
#13 | |
![]() ![]() Drives: 2006 Mazda3 Sedan Join Date: Jun 2007
If you just want to reach the tach signal off the OBD port there are plenty of units out there that can do it for you already, though: http://www.scangauge.com/ |
#14 | |
#15 |
#16 |
Get everyone wanting a Yaris AccessPORT to call or write COBB, otherwise they probably wont make one.
#17 | |
#18 | |
http://www.cobbtuning.com/dealers/Default.asp Some of them in my areas are labeled "AccessTUNER." Probably not a comprehensive list, but it's a start. Just because they currently tune the Subarus may not necessarily mean they tune other car if/when Cobb releases other AccessPort products, though. |
| STOCK SEATS OUT OF HB / stock tires/rims | mrrock | Items for Sale by private party | 19 | 08-19-2009 04:56 PM |
| My first new car... | wagoneer | New YARIS Purchase Forum | 4 | 04-09-2007 03:45 PM |
| ECU pinout | ChinoCharles | Performance Modifications | 78 | 04-08-2007 06:10 PM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
| About hand wash and other methods.... | zyovka | Wash, Wax, Detailing, Exterior Repairs | 5 | 09-27-2006 05:10 AM |
