Old 02-04-2014, 12:30 PM   #1
Blue09
Drives: 09 Yaris hatch 5spd
17inch wheels without losing mpg?
Finally paying off my 09 hatchback this summer and looking to upgrade to some possibly 16 but preferably 17 inch wheels. The only thing Im worried about is losing gas milage with the bigger rims. It is my understanding that as long as you stay within the same over all diameter with tires as factory and under the same over all weight as factory you wont lose any mileage. Is that correct? Any thoughts on the situation? Thanks!
Blue09 is offline   Reply With Quote
Old 02-04-2014, 12:41 PM   #2
With a 17" rim, you'll be increasing the contact patch between the tire and the pavement significantly. This equates to increased rolling resistance and an inherent hit to mpg.
Old 02-04-2014, 09:18 PM   #3
Not to mention the weight and subsequently rotational mass
Old 02-04-2014, 09:27 PM   #4
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
Indeed... I had 16x6 rims before with 205/55/16 tyres... (Original Toyota rims with Yokohama tyres)
Now I'm running 15x7 rims with 185/45/15 tyres... (Rota Grid-V with Nangkang tyres)
Going for 15'' with smaller tyres gives you a noticable increase in acceleration and alot of increase on mpg :)
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 02-05-2014, 02:20 AM   #5
Blue09
Well damn, I was afraid of that. What kinda mpg hit are we talkin between 15 and 17 inchers? 2 mpg? 5 mpg? Thanks again guys
Old 02-05-2014, 08:00 AM   #6
G-Ammo
G-Ammo's Avatar
I dont know in miles... but I noticed my range went from 610km to almost 700km on 1 tank :) so thats quite alot if you ask me :D
Speedbumps suck...!
Old 02-05-2014, 09:08 AM   #7
On our available I went from super heavy sixteens to light weight fourteens and the difference was about 5 miles per gallon
Old 02-05-2014, 09:11 AM   #8
On our available
On our aveo
Old 02-05-2014, 12:21 PM   #9
How does the diameter of the rim determine contact patch? I thought the width of the tire (and related, the width of the rim) determined that.
I run 17's on my Prius C with no loss in mpg. So does our customer Mike on his.
There are 15's that are way heavier than some 17's. A blanket statement like this is completely misleading.
Old 02-05-2014, 12:37 PM   #10
At 17" diameter, you cannot get a tire as skinny as the 185s the OP probably has.
Also, most people do not end up investing the kind of money it takes to get a wheel/tire combo that does not result in increased weight over stock.
Old 02-05-2014, 12:43 PM   #11
So you're confirming that it is the width of the tire that determines contact patch; thank you.
Yokohama S Drives are 195/45/17, perfect for a 17" application on a Yaris.
Mike runs those; I run Sumitomos. He runs Advanti wheels, which are NOT expensive.
Neither of us has experienced a loss in fuel economy.
Old 02-05-2014, 12:57 PM   #12
The Prius is using battery to get itself rolling is it not? You've got inertia working in your favour when actually burning gas.
Who is Mike?
Old 02-05-2014, 01:31 PM   #13
Mike is a customer. I've used 17's on the Yaris as well with no loss in mpg. Heavy wheels and/or oversized (more than ONE width larger) tires WILL cause a loss in fuel economy. Tire brand and treadwear rating will also make a difference.
The OP has plenty of answers to work with now, that's for sure.
Old 02-05-2014, 01:48 PM   #14
Always add lightness
Old 02-05-2014, 02:51 PM   #15
^ ha, I like that
Old 02-06-2014, 01:01 AM   #16
I've gone through, and am still using 17's. Compared to the OEM 15" steelies that came with my car.....
17x7, ET40; 205/40/17. Did not see any mpg loss:
17x7, ET42; 205/40/17. Got a little better mpg:
17x7.5, ET38; 205/40/17. Slightly less mpg:
17x7.5, ET unknown; 205/40/17 and 215/40/17. About the same, maybe very slightly better:
This is what I currently have on, and the heaviest set up I've had at 43.5 lbs per tire/wheel combo. I get about the same as the 15" steelies on the freeway, really tanks in city driving tho. 17x7, ET47, 17x8, ET47; 205/40/17
Last edited by Kaotic Lazagna; 02-06-2014 at 01:06 AM. Reason: Edit: added wheel specs and tire size
Old 02-08-2014, 09:47 AM   #17
venezbras2013
Drives: 2012 Yaris SE
Kaotic: cool versions of your Yaris! Question on those 17x7.5 with ET38mm... any issues at all running those wheels? I'm asking because i bought some Enkei GTC01 with ET38mm and was thinking on running the same tire size you run 205/40R17... any rubbing with that setup? what type of suspension do you have? by the way, I have a 5dr hatchback (SE model). Thanks.
venezbras2013 is offline   Reply With Quote
Old 02-09-2014, 09:25 AM   #18
should have added that all of my driving mileage was in the city, so with all the accelerating and decelerating you really notice the wait wheels. if you drive mostly highway the way to really doesn't matter as much
Chevy Cruze ECO earns an astounding 42 MPG EPA Highway rating! Kal-El Off-topic / Other Cars / Everything else Discussions 26 02-05-2011 11:29 AM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 01:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 12:49 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 06:48 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 07:55 PM
