![]() Drives: 2006 Hatchback Join Date: Mar 2014
Alright, I've read my manual, I've searched the forum, and I'm feeling pretty dumb.
2006 Canadian Hatchback High-beams work (I changed those in the past year) Regular Headlights do not work. Just changed the parking lights which were also burnt out, thinking that was my issue. I tried the parking lights because the manual only list "headlights", nothing more specific. The same bulbs listed under "headlights" were the high-beams I bought recently, so I have no idea what I'm looking for. EDIT: The headlight catalog at Canadian Tire mentioned the headlights were "dual beam" and this site says the beam should be high and low beam. Perhaps I bought the wrong bulbs? Perhaps they are hooked up wrong? Thanks for reading my post |
The Yaris headlights are dual beam within the same bulb. 9003 is the correct bulb type. What were the ones that you purchased?
#3 | |
Scratch part of what I just posted on Kal-El's Mileage thread. Here I thought my High beams had lasted 7+ years, when in reality they were getting refreshed every time (only 4 x total as each side now on 2nd replacement after the bulbs put on the car when it was manufactured) a burnt out low beam was replaced . Of course, it is indeed 9003 (the 9003 code even appears on my AutoZone receipt from earlier today), and is now working perfectly on my Yaris.
#4 | |
Unfortunately, I can't recall the type of bulb. I just bought what the back of the manual specified. HB2 bulbs, apparently. That's all I remember focusing on, 9003 doesn't ring a bell. I didn't keep the packaging, either. So it's possible that I purchased the wrong bulbs, but I'm sure my lights were working normally after they were put in. I just find it strange that the high beams work fine, and the normal intensity fails to fire if it's the same bulb. Perhaps I'll just buy more lights, but I've been trying to avoid that because I'm not convinced my current lights are dead. |
![]() ![]() Drives: Yaris Sedan Join Date: Dec 2012
I just changed mine (07 Sedan Canada). 9003 is the one to go. I got the Sylvania xtravision from Canadian Tire for $30, fits perfectly and apparently have the same color as the original bulb.
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| Sedan HID Projector Retrofit Headlights | !yaris! | Cosmetic Modifications (Exterior/Interior) | 10 | 10-26-2017 03:31 AM |
| FREE Projector Headlights OR LED Tails in exchange for appearance in how-to video | V70R_Blackbrick | California | 4 | 10-13-2013 11:57 PM |
| 2010 yaris Projector headlights | yaris2010RS | Items for Sale by private party | 9 | 01-09-2012 06:31 PM |
| Best Aftermarket Headlights | MadMax | Cosmetic Modifications (Exterior/Interior) | 3 | 06-04-2009 07:50 PM |
