Yaris Owner
Drives: 2009 Yaris 1.8 L 2ZR-FE I4 Join Date: Feb 2011
Patching up Washer Reservoir
Hello, newbie here. Found out that the windshield reservoir is leeking. Any patch-up tips? I looked online and can only find things related to cheap after-market products (whatever that is)
Is it wise to patch-up the reservoir instead of buying a new one? Thank you in advance.
Mizzie07 2009 Toyota Yaris 1.8 L 2ZR-FE I4 Do you own an automotive site? (forum/blogging/carparts) Get ahead of your competition with automotive seo
#2 | |
#3 | |
Yaris Owner
Epoxy wont work?
Epoxy will just flake off of HDPE. Something like GOOP glue would probably work reasonably well, and there are some products specifically made for gluing HDPE, but welding the plastic would be the most effective when trying to contain liquid.
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Honestly I would give a product called Seal All a try. Its about 3 bucks a tube and I've seen it in auto parts and hardware stores. I've used it to patch fuel tanks, oil pans and even a rear diff cover on a heavy duty truck. Just clean the area good with alcohol and you should be good to go.
I patched a major crack in a snowmobile gas tank with it 10 years ago and it's still holding! 3 bucks instead of 110! |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
There have been some totaled cars that you might be ableto get a used one from.
Making a decision without following it with an action is still a fantasy. |
#8 | |
Yaris Owner
#9 | |
Yaris Owner
Thanks all!
Not quite a noob
Why not duct tape both sides of the leak and then heatgun the crap out of it so it melts in?
EDIT: Electrical tape |
#11 | |
Yaris Owner
Not quite a noob
I THINK it might work, because the liquid isn't under pressure, and it's just washer fluid so if it gets a tiny bit contaminated it's not a big deal. That's just what I would do :)
#13 | |
Yaris Owner
Yeah Im thinking heat gun it. Depends on the dammage. Maybe get some ground up whatever it is the tank is made of and put that on the dammage to fill it in?
![]() Drives: stripped sedan Join Date: Dec 2010
They make tank welding kits for hdpe and simular type plastics. Look toward camper tank repair welders. They look like modified soldering pencils and the kits come with hdpe welding rod.
#16 | |
Yaris Owner
#17 | |
Yaris Owner
![]() Drives: Nautical Blue Yaris Sedan 5spd Join Date: Jan 2007
How about......wait for it........buy a new one?
| coolant reservoir? | toad | DIY / Maintenance / Service | 10 | 11-02-2010 11:02 AM |
| Windshield Washer Indicator | captainm27 | General Yaris / Vitz Discussion | 25 | 01-21-2009 07:26 PM |
| motor oil drain plug washer | xpeteyjtx | DIY / Maintenance / Service | 13 | 12-30-2008 01:27 PM |
| New TSB Bulletin For Windshield Washer Sprayer | Yaris | General Yaris / Vitz Discussion | 14 | 06-01-2007 01:47 PM |
