Old 04-21-2014, 03:24 PM   #1
ddeschen
ddeschen's Avatar
Drives: 08 4dr Hatchback
How do I turn a "check engine" off?
It is ON since I fill the gas tank and did not screw the gas cap correctly. There might be a trick to turn it off but can't find on this site. Help please.
ddeschen is offline   Reply With Quote
Old 04-21-2014, 03:26 PM   #2
To reset it without a diagnostic tool, you can disconnect the battery for a couple of minutes.
Old 04-21-2014, 03:46 PM   #3
ddeschen
ddeschen's Avatar
Thanks, I'll try it in few minutes as soon as it stops raining.
Old 04-21-2014, 04:09 PM   #4
ddeschen
ddeschen's Avatar
Thanks CTScott; done!
Old 04-21-2014, 08:37 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
normally it take 40 warm up cycles or 80 Key cycles to clear a DTCs.
Passenger airbag light on making turn signals and cabin fan not blowing? thatbryanguy General Yaris / Vitz Discussion 17 08-16-2024 10:23 AM
Projectors retrofit, black reflectors and dimmed front turn signals my2sense General Yaris / Vitz Discussion 11 06-20-2012 11:39 AM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 06:41 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
