![]() Drives: Yaris Join Date: Apr 2014
2006 Yaris Fuel Pump and relay
Hi all,
My first post here, so I hope I'm thorough enough. My wife's Yaris is having the dreadful issue of not starting. It cranks but just will not turn over. I have an engine light on. I have checked: Battery OK All fuses OK Fuel level half full Spark plugs OK (1 month old) Removed one spark plug, grounded to battery and confirms it fires Only thing I am left to think is that the fuel pump has died. I can't hear it pumping any fuel prior to turning the key over. I am having issues locating the fuel pump relay. Can anyone tell me where to find it? I am in Australia so chances are that the location of fuse boxes is different to America etc. One thing I have done is removed the rear seat and removed the cover for the fuel pump/filter assembly. When I removed one of the tubes (middle tube that has the yellow clip http://www.yarisworld.com/forums/showthread.php?t=42906) and it poured out with some fuel and the splattered air and fuel and then stopped. I assume this is because I didnt remove any pressure from it via the fuel fill cap. ANY help would be greatly appreciated. |
| Tags |
| fuel, fuel pump, fuses, relay |
| 07 cranks, won't start--no fuel?... | tylerwatts53 | DIY / Maintenance / Service | 18 | 03-03-2014 06:03 PM |
| fuel pump relay with standalone | Radou | Performance Modifications | 0 | 07-10-2013 06:06 PM |
| Fuel Pump Relay | bronsin | General Yaris / Vitz Discussion | 4 | 08-07-2012 08:19 AM |
| Help, Rear Defogger shuts off Fuel Pump | sm2by | DIY / Maintenance / Service | 3 | 05-30-2011 01:10 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
