![]() ![]() Drives: 2015 Yaris Coupe Join Date: Jun 2012
Air Bag Question
I removed seats to install 2 amplifiers for my stereo system.
I disconnected neg bat terminal when installing. Then I connected battery and turned on ignition with air bag harness disconnected. Of coarse I reconnected airbag harness with battery terminal off. Do I need to have my airbags reset ? I mean like everything should be working right ? I sat on the passenger seat and saw the light on the dash say airbag on. Any feedback appreciated, Thanks |
If you started the car with the airbag disconnected the SRS ECU would log a DTC and the airbag light on the cluster will stay on until you clear the code. Unplugging the battery will not clear airbag codes. They have to be reset using the Toyota TechStream service tool or this procedure:
http://www.yarisworld.com/forums/sho...d=1#post557473
| My "passenger air bag ON" lights turns off when headlights turn on? | Henry_mak16 | DIY / Maintenance / Service | 1 | 06-19-2013 03:37 PM |
| Yaris AIR BAG Passenger light - explanation needed | Abk911 | DIY / Maintenance / Service | 10 | 04-17-2013 12:36 PM |
| A different Air Con and FE question | *MAD DOG* | Fuel Economy Forum | 9 | 02-22-2009 11:11 PM |
| Question about air conditioning power consumption | voodoo22 | General Yaris / Vitz Discussion | 15 | 09-21-2007 12:14 AM |
