![]() Drives: 2008 Toyota Yaris 2D Join Date: Apr 2014
Anyone replace their oil drain plug with one of these?
http://www.qwikvalve.com/
I just read about this on some blog, anyone use one? Any problems? I think this would be great if you change your own oil. And if you decide you don't want to change your own oil once in a while just bring the plastic bit and the hose with you to the oil change place. So. How long have you had it on your car? And have you had any problems with it? |
Yes. I have Fumoto quick valves on all of my vehicles. The oldest one I have had on for over 5 years without issue. If you are lowered, you need to be careful as the valve hangs lower than the drain bolt head would have.
Car is stock height. They have one that is made for cars that have been lowered. I'll probably end up getting that one as i do go over speed bumps quite often.
#4 | |
![]() Drives: '08 Yaris Join Date: Apr 2014
They do recommend you install the safety spring just in case, which I would highly recommend because it also keeps some punk from draining your oil easily should they be crawling around underneath your car for whatever reason. The valve adapter and safety spring I bought for my RX-8 is still new in the box. I'd give mine to you but it looks like the drain plug size is not the same. |
![]() Drives: 2010 Yaris LB Join Date: Jan 2011
I put these on every car I own at my first oil change. Sometimes the lever might not be oriented exactly the way you want, but I've never had any leaks or issues. Well built units.
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
I got one a couple years ago and I had the unfortunately luck of the valve stripping my oil pan and leaked oil. I'm a small percentage of this happening, but thought I'd let you know it does.
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
I just replaced with one of these:
![]() Monitoring engine wear without paying for UOA. |
Looks like a magnetic drain plug to me.
It's a goldplug. http://www.goldplug.com/
i have one of those in mine. There are fine metal particles on the plug each time i change oil... |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
I have been using those for a long time. Some cars seem to always have a
little bits attracted. Cheap insurance, if you change your oil. Steve |
![]() ![]() ![]() Drives: Yaris sedan Join Date: Jan 2009
I can't have that here, car scrapes everywhere :(
Got them on my Bike and Land Cruiser, but I don't like the location for the yaris, so I past. Plus I change my oil once per year, so it's not all that needed in my case.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| oil drain plug- gasket | eddy | DIY / Maintenance / Service | 38 | 10-17-2009 11:00 AM |
| Oil Drain Plug Size? | Nigal | DIY / Maintenance / Service | 4 | 05-31-2007 01:55 PM |
