Old 01-25-2014, 07:38 PM   #1
CB900F2
Drives: 08 Sedan
HVAC Fan
Hey guys..
I was talking to the wife today in the car and I had the HVAC set to speed 1, and she commented how loud a hum it makes... I always knew it was loud, but I guess over the years I kinda forgot how loud it was...
How loud do you guys/gals find your fan when set to the first speed setting??
Again, it is a very noticeable hum sound at this setting.. And the cold really has not effect, and it is the same even in the summer....
Thanks everyone..
CB900F2 is offline   Reply With Quote
Old 01-25-2014, 08:48 PM   #2
RJay
Drives: 2002 Toyota Yaris T-sport
No, on the first two settings my fan actually barely makes any noise. With or without a/c on.
off course on the second it does make some noise but it's easily drowned out by the radio.
198X BMW E30 modified race car
1975 Ibanez "Les Paul custom"
RJay is offline   Reply With Quote
Old 01-25-2014, 09:59 PM   #3
If you do not have a cabin air filter installed the hum may be due to something having been sucked into the fan (like a piece of paper from the glovebox).
Old 01-25-2014, 10:44 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
Mine does make a little humming sound when it's running. I should make a video of the sound. Not sure how well it will turn out but i'll try...
I don't like the noise it makes, but i guess it's the way it is.. My Echo made the same noise.
Old 01-26-2014, 09:53 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
my Echo's doesn't make any noise other than the sound of air coming through the vents.
Old 01-26-2014, 10:14 AM   #6
CB900F2
Drives: 08 Sedan
Hi Scott.. I had a cabin filter front new.. I did find a another thread and it was noted that toyota changed the part# of the blower around 2010/09 , so I am going to assume they revised the blower motor and maybe to address it being a bit noise.
Old 01-26-2014, 10:39 AM   #7
Interesting - I just looked in the EPC and there are 2 different part numbers. 87103-52140 and 52141. I have 52140 on my 07 and 08 and 52141 on my 09. I don't hear a difference between them. The part number is on the center of the bottom of the blower motor.
Old 01-26-2014, 01:27 PM   #8
IllusionX
I just made a little 30s video of the noise my fan makes.
https://www.youtube.com/watch?v=w1ElLu9NW4M
Old 01-26-2014, 02:03 PM   #9
Bluevitz-rs
It just sounds like bad bearings to me.
Old 01-26-2014, 03:47 PM   #10
CB900F2
Drives: 08 Sedan
He guys.. Here is a link to a video of the sound from my skydrive.. I hope the link works..
https://www.dropbox.com/s/f76wcj0uzu...D_00000007.mp4
Old 01-26-2014, 03:51 PM   #11
Bluevitz-rs
900, that sky drive thing doesn't work for me. Can you put it up on YouTube or photobucket?
Old 01-26-2014, 05:41 PM   #12
CB900F2
Drives: 08 Sedan
Hi Blue... I used my drop box and tested it from another workstation and all is good to watch and hear the loud hum....
my link is ^^^
regards
Old 01-26-2014, 10:32 PM   #13
IllusionX
I think CB900's sounds like a bad bearing. Mine always sounded like in my youtube video... and my Echo also sounded like this...
Old 01-27-2014, 10:45 AM   #14
It definitely does not sound normal. I haven't taken one far enough apart to see if the motor has bearings or is simply a cheap bushing type motor. I have a couple of quiet spares on hand, if you would like to replace it.
Old 02-10-2014, 09:50 PM   #15
CB900F2
Drives: 08 Sedan
Hey guys..
Ordered a replacement from rockauto, and installed it an all is good now....nice and quiet..
I decided to take apart my old one too see what was the issue, and when I took apart the motor, it was a bad bearing... It was a bitch to take off the fan , not meant to be serviced..
Old 02-10-2014, 10:57 PM   #16
Bluevitz-rs
Cool. Any pictures you could take? Also, do you think you could put it back together and use it again?
Old 06-07-2014, 02:02 PM   #17
fasteddie07
Drives: 2007 Toyota Yaris
CB900F2: Do you have the part # for what you purchased from rockauto?
My fan's noist too...
TIA
fasteddie07 is offline   Reply With Quote
Old 06-10-2014, 09:39 AM   #18
CB900F2
Drives: 08 Sedan
Hi Fasteddie... The part search tool at Rockauto is very easy to use... There is only one supplier (TYC) listed..
Anyone try a Ducted fan? UberSilver Forced Induction Forum 5 06-07-2013 11:57 PM
HVAC BLOWER ISSUES yaris2010RS DIY / Maintenance / Service 18 12-29-2012 11:23 PM
Fan Not Spinning Up, Random Airbag Light drannonb DIY / Maintenance / Service 12 10-23-2012 03:33 PM
AC Blower Motor / Fan Does Not Turn on Period dyslexicanaboko DIY / Maintenance / Service 7 01-30-2012 10:59 PM
Abnormal radiator fan hi577 DIY / Maintenance / Service 0 01-21-2012 03:34 AM
