Transmission filter?
Hi all, Just thought I'd ask if any of you have had your Auto trans filter out? If so, is it a filter or a screen? Can it be cleaned or is it one time use?
Thanks.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
![]() ![]() Drives: 2007 2DR Liftback Join Date: Oct 2011
Filter, not a screen. See my very recent post elsewhere in this forum, and many others' comments too. Use the correct fluid!
#3 | |
I never gave mine a close look. It's odd that Toyota charges $85. for the filter, but the WIX I installed in mine about a year back cost me $11. from rockauto.com. I'm glad to hear I did not toss a cleanable OEM filter/screen.
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
Make sure your "filter kit" (filter, o-ring, gasket), comes with a cork gasket not a rubber one.
Mine came with a rubber gasket. Cork is better in this application. I did a drain & fill 1st. Then drove it for a few hundred miles, another drain, replace filter, and fill. |
#5 | |
I'll bite, why not the rubber gasket?
Compresses too much. No feel for how tight the bolts are. Using a torque wrench I still ended up breaking one bolt. Bad bolt or crappy torque wrench.. Dunno. PITA though.
Your supposed to re-tighten / re-torque all the bolts after everything heats up with rubber. Not necessary with cork. |
#7 | |
The rubber on mine has been good for the last year. I did use Toyota Black caulk on the pan side, and Low Strength Loctite 222 on the bolts.
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Changed out my auto filter last night and a lot messier then I was expecting. I used a Beck Arnley and it came with a rubber gasket.
So far so good. But I would have preferred cork also for the gasket. I paid $17 for the kit, and I decided to give the dealership a call and see what they would have charged for the filter and gasket.. I was shocked!.. $145 for the filter, and $25 for the gasket. |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| Beware WIX Filter #51394 | zkay | DIY / Maintenance / Service | 19 | 12-22-2012 01:09 AM |
| DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 12:03 PM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
| Installing a external in line transmission filter. | YarisSedan | Performance Modifications | 1 | 03-31-2009 09:03 PM |
