Old 08-18-2014, 11:34 PM   #1
vinooooo93
Drives: Toyota Yaris 2006 Sedan
Small crack found in engine. Concern ?
2006 Sedan.
Sorry for the newbie question but I was wondering if this crack (which is quite small) is of a concern? Is it just a plastic covering ?
Just FYI, the 'stop and check engine light' doesn't appear when I'm driving nor do any other dashboard indicators. Also haven't noticed any differences in driving the car as of yet.
Pics:
1) http://i.imgur.com/fAWF9Or.jpg
2) http://i.imgur.com/VKGYQXS.jpg
thanks in advance!
vinooooo93 is offline   Reply With Quote
Old 08-23-2014, 05:32 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
What he said, if that is an actual hole instead of a surface scratch, fix it soon.
Colin Chapman disciple
Old 08-23-2014, 06:12 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
start car , light smoke and blow smoke over hole and see if it actually is a hole or just a small imperfection ...kind off like a smoke machine when looking for vacuum leaks ..if smoke goes in u have a leak if so fix it :P
Old 08-23-2014, 06:25 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
you can pick up a used intake manifold for like 50 bucks which is much cheaper than what could happen.
Old 08-23-2014, 07:28 PM   #5
bronsin
bronsin's Avatar
That's the intake manifold not the engine block. Which is plastic...engine block metal.
If it were a hole I would have to believe the engine would not be running normally and the check engine light would be on.
But blowing smoke at the hole from a cigarette and seeing it sucked into the engine would prove me wrong! Also, spraying a can of starting fluid at the hole and hearing the engine speed up would confirm its a hole.
Old 08-23-2014, 09:27 PM   #6
When I bought one of my wrecked ones the alternator had been pushed into the intake manifold and it took a chunk out of that runner. The car ran slightly rough, but I was amazed that even sucking in that extra air that it did not through a code. I suspect that it would have thrown a lean code on that cylinder if I pushed it.
That being said, the O.P. should definitely patch the hole or replace the manifold. I patched mine with black silicone and it has been running fine on Crashy for quite some time.
Old 08-24-2014, 08:20 AM   #7
bronsin
bronsin's Avatar
Since the manifold is plastic epoxy will do it. No need to replace it.
Old 08-24-2014, 09:28 AM   #8
nortonfb
Drives: 2007
Quick way to check for a air leak is to spray WD40.
If the idle increases you have a leak.
Steve
nortonfb is offline   Reply With Quote
Old 08-28-2014, 02:50 PM   #9
esse10
Drives: 2009 yaris 2 door
2x
I would jb weld it , patch the hole man. jb weld is only $3-4 bucks.
esse10 is offline   Reply With Quote
Old 08-28-2014, 10:14 PM   #10
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
A little high heat permatex in black can also seal the crack..
yaris1F8 is offline   Reply With Quote
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
TC swap? MicroHB Performance Modifications 38 03-26-2009 12:39 AM
Need help badly looking for engine swap places in gta Adriaan Canada 7 02-23-2009 08:14 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
