![]() Drives: yaris Join Date: Aug 2014
smooth boot lid
hi
im looking to buy a Toyota yaris 99-2005 model its going to be a 3 door im just enquiring on how to get the smooth boot lid finish? is it just a complete separate boot or is the boot modified? thanks.
When you see one with the emblems removed, it was modified. The Yaris and Toyota emblems can be easily removed with a little heat or by using dental floss to cut the adhesive behind them. The Toyota logo can also be removed, but from what I have heard, some MK1s do not have holes behind the logo and some have two small alignment holes.
The rear wiper as well can be removed, but a ~25mm hole is left behind that has to either be plugged or patched.
#3 | |
hi there ctscott
I understand that the badges can be removed but what about the boot lid switch how do people open their boots once removed? |
That gets a little more complex. You have to add a solenoid to pull or push the lever that used to be flipped by the hatch handle. That solenoid is then driven by a key fob remote and an output of a keyless entry system.
I see, what about the latch that opens the boot from the outside can that be removed?
Yes. That is the purpose of the solenoid - To eliminate the need for the outside latch.
| Center Console Lid Pops Up! | Rigojr | DIY / Maintenance / Service | 8 | 11-19-2021 05:31 PM |
| Suede Shift Boot and Grant Evolution BLK/CF Knob | fnkngrv | Cosmetic Modifications (Exterior/Interior) | 12 | 04-04-2011 08:37 PM |
| Shift boot question. | Black_griffin6 | Cosmetic Modifications (Exterior/Interior) | 14 | 02-06-2011 10:32 AM |
| Redline shift boot | PHXDEMON | Cosmetic Modifications (Exterior/Interior) | 27 | 10-01-2009 12:14 PM |
| Shift Boot ... revisited | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 35 | 04-19-2007 07:04 AM |
