Old 09-07-2014, 05:01 PM   #1
SpeedyYaris
SpeedyYaris's Avatar
Drives: 2009 3door 5-speed Manual
Rough Shifting Long term effects?
Hello i have a Yaris manual and I just changed the transmission fluid... It ALWAYS shifts HORRIBLE the first 5 minutes of driving in the morning... The car jerks very hard and shakes violently And then after about 5 min its back to normal and shifts very smooth... I thought changing the transmission fluid would help but it didnt.. I got it changed at Toyota.. IM just wondering if I am damaging the transmission at all and how should i go about this rough shifting in the morning?? should i just Keep the clutch in for a long time so i can make it smooth as possible?? Am i damaging the engine at all? thanks in advance. I do have about 70k on the car on original clutch.. Maybe the clutch is bad??
SpeedyYaris is offline   Reply With Quote
Old 09-07-2014, 07:32 PM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
During the first minutes, your idle rpm is high. So shifting wont be as smooth as warmed up.
But at what RPM are you shifting tho?
Check out my Build thread:
Old 09-15-2014, 09:52 PM   #3
SpeedyYaris
Mine doesnt have the tach.. It drives me crazy haha.. But starting from a stop right when the clutch is completely let out the car shakes HORRIBLY lol and then it is fine and then shifting to second jerks the car no matter how smooth i try to make it. I feel like im damaging the engine or Cylinder heads?
Old 09-07-2014, 08:23 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
My idle is at 2000rpm when I first start up. I always shift like crap the first thing in the morning and when I leave work.
Old 09-07-2014, 10:38 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Do you mean that it jerks back and forth when you try and coast? Mine does that in 1st and 2nd, but not as bad in 3rd.
If you mean that it's hard to put into gear, then it could be that your cables are worn out. Maybe post up a video?
Old 09-15-2014, 10:18 PM   #6
CrankyOldMan
Sounds like you need a new clutch.
Old 09-16-2014, 04:25 PM   #7
nookandcrannycar
^^^^^ This. The clutch on my 2007 has 295,000 + miles on it, and it is not acting even in the same ballpark as what SpeedyYaris is describing.
Old 09-16-2014, 05:12 PM   #8
CrankyOldMan
I have similar behavior from mine, but only if I leave the trans in gear and my foot on the gas pedal. Any bumps/movement of your foot creates a positive feedback loop, making the car lurch more and more violently. The only practical way out of the loop is to push in the clutch pedal and then coast in neutral.
When I had the gearbox out this weekend, I checked the clutch out--LOTS of dust in the bell housing, but still plenty of material on the wear plate. That said, the clutch has about 40k of HARD driving on it, the last 15k or so with increased HP. Perhaps a new one is in order before next year's racing season...
Old 09-16-2014, 06:20 PM   #9
nookandcrannycar
I'm fairly easy on my clutch, but even that has its limits. IIRC, trini got 448,000 miles out of his OEM clutch and yaris9876 got 403,000 miles out of his OEM clutch. I doubt I'll get close to either of those numbers.
Yaris long term durability champ vs FR-S and Miata regal Off-topic / Other Cars / Everything else Discussions 12 08-15-2012 08:22 PM
What is your long term fuel trim? Yury General Yaris / Vitz Discussion 2 01-17-2012 07:50 PM
valves/cyclinder head long term reports regal DIY / Maintenance / Service 3 05-21-2011 11:03 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 04:41 AM
