![]() ![]() Drives: 2012 Yaris L 3Dr Join Date: Aug 2009
MR-2 wheels and tire questions
Hey everybody! I picked up some pretty nice MR2 Spyder wheels today (unfortunately the tires are the wrong size, so I will be getting new ones, but that's ok, they were a great deal anyway)
![]() As you may know, the MR2 wheels are 6" wide in the front and 6.5" wide in the back, so I will be running a staggered wheel set. I am thinking I want to run the 6.5" up front and the 6" in the back with penguin 10mm spacers. Anyway, I want to run the same size tire on both front and back and I'm trying to decide if I should go 195/55 or 205/55. On the 6.5" wheel, 205/55 should fit well, but I'm worried it might be a bit large for the 6" wheels. I could run 195/55, but the tire is about 2% fast and I want to try to get as much tire as possible in those wheel wells. I will be using these for daily drivers and occasional (non-competitive) autocross weekends. So, what would you recommend? Thanks! :-) |
205/55's fit OK on 6" wheels, but that size won't fill up the tire as nicely as 6.5".
I have PG spacers myself and 205 will rub on the rear passenger side fender unless you plan on removing the rear seat. Otherwise you may want to get a thinner spacer for the right side, which is something I plan on asking Joel@PG myself at some point. I also added a little camber to minimize the problem, and it got better but it's still not quite there yet.
Last edited by tk-421; 07-21-2012 at 02:20 AM. Reason: fitment "OK" instead of "great" |
Hmmm...thanks for the info. What offset wheels are you running that they rub? Are they the 38mm in your garage?
+38 offset.
Ok cool thanks... Hopefully these won't be a problem since they are 45mm... But maybe I can get them to work...
I think you'll be fine. Rubbing is not terrible, but it is annoying. I'm looking to roll the fenders a bit, which should also help, but it's surprisingly difficult to find those around here...
Well, I decided to go with the 195/55 R15 Firestone Firehawk Wide Oval Indy 500, more because it was what they have in stock since I have a coupon for $100 off in-stock tires over $500. So hopefully I won't have to worry about any scrubbing. I have an appointment tomorrow morning at 9am...
In related performance news: Also installing my TRD springs tomorrow. :) |
I think you made the right choice. Another advantage is that the tires will be a bit lighter as well. Less rolling resistance FTW.
They look great!
Nicely done!
Man those rims match everything lol. I also own a set with 195/55r15 for strictly winter use
#12 | |
Start another Oil Thread!
a classic wheel. i used to have them on my corolla. i also used to have them for about 30 minutes on my MR2 spyder ;)
you nailed it sir.
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Looks great!
Don't forget though that the staggered setup on the Mr2 Spyders was only for the 2nd revision of them. The first model year up until the 2002 models, had the same size rims and tires all the way around.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
#14 | |
that's not the truth.
you nailed it sir.
all mr2 spyders had staggered rims. the first version was just staggered width. Second version had 15" fronts and 16" rears.
Really? Everything I've read on the mr2 spyder forums stated that first gen spyders had 15" rims and same size tires all of the way around. Second gen spyders is when they went 15" fronts and 16" rears with differeing tire widths as well. -shrugs-
やりすぎだ~
This should sum it up.
2000-2002: Front Wheels Width 15x6 Offset = et45 PCD = 4 x 100 Front Tires = 185/55/15 Rear Wheels Width 15x6.5 Offset = et45 PCD = 4 x 100 Rear Tires = 205/50/15 2003-2005: Front Wheels Width 15x6 Offset = et45 PCD = 4 x 100 Front Tires = 185/55/15 Rear Wheels Width 16x7 Offset = et45 PCD = 4 x 100 Rear Tires = 215/45/16 |
Wow well I stand corrected, I'm glad to know this. Thanks!
| Wheels and Tire package, CHEAP!! | kngrsll | Tracking, Racing, Auto-X Forum | 3 | 04-01-2010 01:44 PM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 05:46 PM |
| Rim and Tire Questions | kustom play | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 12-02-2008 10:32 PM |
