Old 02-19-2007, 03:01 PM   #1
drg
Drives: 07 Yaris Hatchback
Resetting Service Required Light
I change my own oil but the damned service required light came on and really did not want to take my Yaris to the dealer to get the light reset so I tried a few things, this is what I think I did to get it off.
1. Turn the ignition all the way on.
2. Turn the ignition off.
3. Press in and hold the trip meter reset button.
4. Turn the ignition all the way on. I noticed the service button blinking
5. After about five seconds, turn the ignition off. Then release the trip meter reset button
6. Turn the ignition all the way on. The service light comes on and then goes off after a few seconds.
If someone else has one of these lights on, give it a try and see if I remember correctly.
drg is offline   Reply With Quote
Old 02-19-2007, 03:03 PM   #2
drg
I forgot to say release the trip meter reset button between 5 & 6.
Old 02-19-2007, 05:31 PM   #3
magoo_lc1
Drives: honda civic hatch
While holding a metal rod and standing on one foot?..lol. J/K sounds like a good tip.
91 SE-R. R.I.P old freind
The influence of peers on individual behavior illustrates the seductive power of conformity
And, I don't mind at all being looked down upon by purists. Indeed I don't mind at all being looked down upon by those whom I do not look up to at
magoo_lc1 is offline   Reply With Quote
Old 02-19-2007, 09:21 PM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Also found in your owners manual, and in about 10 posts from the past fro here.
Nice bump though, this topic on reseting after an oil change should become a sticky.
Old 02-20-2007, 07:49 AM   #5
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
...I second that Chris07LB ! I can name alot more "stickys" too!
sambo42xa
Southern, NH
sambo42xa
sambo42xa is offline   Reply With Quote
Old 02-20-2007, 08:10 AM   #6
stickied, much more convenient than unplugging the battery for a few minutes!
Old 02-20-2007, 11:51 AM   #7
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
The odometer has to be in the "Trip A" setting first.
Old 02-20-2007, 12:23 PM   #8
RogueYaris
Drives: 2015 Abs Red
I took my car to the dealership and watched them reset it.
1. With the odometer on trip A and the ignition off, press and hold the reset button.
2. Turn the ignition on (no need to start the car) and wait for it to start blinking. It will count down and when it's done, it'll be reset.
RogueYaris is offline   Reply With Quote
Old 02-21-2007, 09:59 PM   #9
AaronATL
AaronATL's Avatar
Drives: 2007 yaris hatchback
what does the button next to the automatic shifter do?
you have to take a key and pop the cover and
under it has a white plastic button looking deal
bambuzzled again
AaronATL is offline   Reply With Quote
Old 02-21-2007, 10:06 PM   #10
Typer73
Tired of the Stars!
Typer73's Avatar
Drives: '07 Meteorite LB
bambuzzled again
Is that the same spot as the aux input for Ipod?
Typer73 is offline   Reply With Quote
Old 02-22-2007, 07:17 AM   #11
Chris07LB
Chris07LB's Avatar
If your car is ever locked out of gear, it allows you to move the shifter in and out of gears so it can be driven to the dealer.
Old 04-12-2007, 10:17 PM   #12
mkorejwo
mkorejwo's Avatar
Drives: 2010 5 door hatchback
Toyota states it in the manual, rather well.....
Buried on page 121 of the handy manual.....
ref: 2007 Yaris hatchback from Jan '06 Prod (OM52700U), page 121, item (m):
The system must be reset after the engine oil replacement. Reset the system by the following procedure:
1. Turn the ignition key to the "OFF" position with the trip A reading shown.
2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
Hold down the knob for at leat 5 seconds. The indication light flashes and the bars displayed in the odometer disappear gradually. The odometer indicates "000000" and the light goes off.
If the system fails to reaset, the light will continue flashing. "
Well these instructions seem reasonable. Toyota isn't telling us the mileage interval (probably 5000 miles) and it probably can be reset anytime, and the light will turnon when 5000 miles has elapsed.
mkorejwo is offline   Reply With Quote
Old 04-18-2007, 05:05 PM   #13
JadeSeaYaris
Drives: Jade sea 07 yaris sedan
I tried it this morning. I set the ODO on trip A and turn the ignition key to OFF i held the Trip Meter button and turned the ingition key on. The light blinked faster than normal and the Odometer read - - - - - after about 5 seconds the light disappered
JadeSeaYaris is offline   Reply With Quote
Old 06-12-2007, 10:38 AM   #14
FunkyCole
FunkyCole's Avatar
Drives: 07 Toyota Yaris
Very good info guys I just reset mine this morning. Thanks
FunkyCole is offline   Reply With Quote
Old 07-04-2007, 07:59 PM   #15
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
I just did mine, thanx for info.
5200 miles
yaris4062007 is offline   Reply With Quote
Old 07-26-2007, 07:27 AM   #16
r300f28
Drives: 2007 Yaris Sedan
Changed my oil last Saturday & had none of the above problems. No service required light came on, NOTHING NADA. Been driving car for a week since.
2007 Yaris Sedan.
r300f28 is offline   Reply With Quote
Old 07-26-2007, 06:44 PM   #17
Chris07LB
Chris07LB's Avatar
Its preset into the computer. You just changed it before it came on. At least when it does come on, you will already know the reset.
Old 07-30-2007, 10:39 PM   #18
Matt_in_Mpls
This trick just saved me a bunch of annoyance--for a different issue. I've had my hatch for 2 weeks. Today I was on a round of trips, and on one re-start, the Power Steering light came on, just as I noticed there was no Power Steering. I just tried this re-set, and it worked--and now I have Power Steering again.
Matt_in_Mpls is offline   Reply With Quote
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 04:09 AM
service engine light @ 9000 mi? dandj DIY / Maintenance / Service 21 01-03-2007 01:30 AM
"Airbag" center console light on 07 Sedan with side airbags atebit In Car Entertainment + Electronics (audio / video / alarm) 5 11-10-2006 07:10 PM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 04:06 PM
Interior Light Kit... for Canadian version?! Jem_hadar Cosmetic Modifications (Exterior/Interior) 5 08-17-2006 03:20 AM
