Old 10-31-2014, 09:08 PM   #1
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
Horn Button Replacement
How could I tap into my horn button wires to add/replace my broken horn button to my dash. Gonna check into wether it'd pass inspection here.
Sent from my iPod touch using Tapatalk
BobTheYaris is offline   Reply With Quote
Old 10-31-2014, 09:30 PM   #2
The horn switch wire is the one lone black wire on the white connector that goes into the clock spring at the base of the steering wheel. Ground that wire to make it honk. Before you do so though, check the tiny green wire that goes to the horn itself, as I have seen more damaged ones of them than problems with the horn switch itself. The horn switch usually fails on, rather than off, as it is the entire metal area of the airbag mount with some very thin plastic spacers that prevent it from constantly honking.
Old 11-04-2014, 12:25 PM   #3
BobTheYaris
It failed on due to blunt force trauma. So its dafe to say those spacers are dead. Would you happen to know if theres enough depth behind the spokes to locate buttons there?
Old 11-04-2014, 12:31 PM   #4
Ah, that makes sense. Those plastic bushings are quite fragile.
The lower portion of the side spokes have enough space for a push button switch.
Old 11-04-2014, 01:22 PM   #5
BobTheYaris
Awesome thanks, hafta pick some up
Yaris Horn install 15 Mins, WOLO 380 2T, Stock is too weak. WRX Third Gen Yaris General Discussion 2 04-19-2014 10:07 PM
DIY Horn Replacement. screenprintr DIY / Maintenance / Service 9 12-29-2012 01:29 AM
NRG and still have horn button?? Jerkratt Cosmetic Modifications (Exterior/Interior) 9 04-08-2011 08:42 AM
FOR SALE: Steering wheel, shift knobs and Horn Button. Yaris T-Sport Items for Sale by private party 15 11-11-2009 09:54 PM
