Old 11-13-2014, 09:20 AM   #1
hondajt
hondajt's Avatar
Drives: 2013 Yaris LE 5Dr
I need help removing an interior trim piece.
I'm doing some custom wiring and need to remove the interior piece at the left knee, the little pocket piece to the left of the knee airbag. It currently houses the mirror position switch and the dimmer, and an extra empty space I'm going to use for a switch for footwell lighting.
I'm afraid of breaking a clip, but i cant seem to find a loose spot to even begin to pry.
Anyone have an idea?
hondajt is offline   Reply With Quote
Old 11-13-2014, 10:53 AM   #2
hondajt
hondajt's Avatar
I just bought a two day subscription to the toyota service manual thing, and STILL can't figure out how to take this out. Anyone have any experience removing interior trim pieces? I'm sure there is a tool i should be using, but don't have. I'm using a flathead screwdriver wrapped in painters tape.
The one with the 5 clips and two claws is the one I need help with.
Old 11-13-2014, 10:55 AM   #3
The clips for that blank are best released by squeezing them from behind. If you can't get behind it, the clips are at the top and bottom, so you would have to get something very thin in there to release them.
Old 11-13-2014, 11:17 AM   #4
hondajt
hondajt's Avatar
Thank you so much!!
Old 11-13-2014, 12:17 PM   #5
hondajt
hondajt's Avatar
Got it out finally! Bought an O-ring removal tool, came off easily!
Please delete/lock this thread.
I'll post some pics later when I've completed my projects!
On a side note, taking this piece off made wiring SO much easier/faster!
DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) CTScott DIY / Maintenance / Service 1 08-21-2013 04:57 PM
So I lost a two cent piece of plastic from the center vent hayden DIY / Maintenance / Service 3 05-07-2011 05:17 PM
FS: Dashboard Covers for the '07-'09 LB, ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 14 09-25-2009 01:21 AM
FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 2 08-23-2009 03:37 AM
Canadian DD trim piece. Can any of you Canadian members get one? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 12-20-2008 01:52 AM
