Old 10-25-2013, 09:45 PM   #1
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Quick Turbo Question
Which side determines how fast a turbo will spool?
The Compressor A/R or the Turbine A/R?
The reason I ask is because I see this;
Fast Spool, 0.42 A/R Compressor, 0.86 A/R Turbine
Thanks
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 10-25-2013, 11:04 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Both...but turbine is more important.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 10-27-2013, 03:51 PM   #3
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
Turbine A/R .. determines turbo spool up speed
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 10-27-2013, 10:06 PM   #4
Ryze268
Ryze268's Avatar
so ideally a small turbine is required ? What does the compressor A/R determine ?
Old 10-28-2013, 12:40 AM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The better question is what are you trying to do
Old 10-28-2013, 02:06 AM   #6
straight from Garrett website:
http://www.turbobygarrett.com/turbob...housing_sizing
Compressor A/R - Compressor performance is comparatively insensitive to changes in A/R. Larger A/R housings are sometimes used to optimize performance of low boost applications, and smaller A/R are used for high boost applications. However, as this influence of A/R on compressor performance is minor, there are not A/R options available for compressor housings.
Turbine A/R - Turbine performance is greatly affected by changing the A/R of the housing, as it is used to adjust the flow capacity of the turbine. Using a smaller A/R will increase the exhaust gas velocity into the turbine wheel. This provides increased turbine power at lower engine speeds, resulting in a quicker boost rise. However, a small A/R also causes the flow to enter the wheel more tangentially, which reduces the ultimate flow capacity of the turbine wheel. This will tend to increase exhaust backpressure and hence reduce the engine's ability to "breathe" effectively at high RPM, adversely affecting peak engine power.
Conversely, using a larger A/R will lower exhaust gas velocity, and delay boost rise. The flow in a larger A/R housing enters the wheel in a more radial fashion, increasing the wheel's effective flow capacity, resulting in lower backpressure and better power at higher engine speeds.
Old 10-28-2013, 02:02 PM   #7
fnkngrv
fnkngrv's Avatar
+1
Old 10-29-2013, 12:44 AM   #8
Ryze268
Ryze268's Avatar
Thanks much, that explains everything and..
I'm going boosted of course, even if it's just 6lbs
Old 10-29-2013, 12:14 PM   #9
fnkngrv
fnkngrv's Avatar
Understood, but in order to provide any real assistance we need to know your goals. There are still some folks around that can give you solid info, but also as well one of the first suggestions is to look at the Zage kit that MicroImageOnline sells and for that you can contact cali yaris especially if you are looking to go with 6psi.
Old 10-23-2014, 07:20 PM   #10
Ryze268
Ryze268's Avatar
Some more turbo questions:
I'm gonna be tuning with an AEM F/IC
1) Do I need to keep the factory O2 sensor?
2) Do I need to keep the factory MAF?
3) Can I just splice in extra wires to extend the above sensors to relocate them to where they need to be?
I'm still in the process of getting things together so I'm sure I'll have more questions soon.
-Justin
Old 10-23-2014, 07:57 PM   #11
-Justin
Yes to all 3. An AEM F/IC is a piggyback, so the OEM ECM is still doing the work and the F/IC is just supplementing it, so the OEM ECM still needs its sensor inputs. If you went with an AEM EMS, which is a standalone, then you could switch to a MAP sensor and only run a good wideband AFR sensor to feed the EMS.
Old 10-23-2014, 09:16 PM   #12
Ryze268
Ryze268's Avatar
Thanks a lot, I will be extending the wires then.
What is the FIC MAF Clamp all about?
I intend the run the injectors(1ZZ) using the FIC only, is that a good idea?
Here's a look at the Manifold & Turbo so far;
Old 10-23-2014, 09:33 PM   #13
I like that manifold.
The MAF clamp feature of the F/IC prevents the ECM from seeing boost (i.e. out of range values from the MAF that would cause the ECM to throw a trouble code).
Old 10-23-2014, 09:54 PM   #14
Ryze268
Ryze268's Avatar
Thanks, I got the idea from boostedxa :)
I'm off from work Saturday so I'll begin mounting everything. I'm in need of the oil feed & return lines so I'll have to order those from eBay (local stores want $300 XCD)
Old 10-24-2014, 12:10 PM   #15
BoostedTRD
Drives: 09 Yaris Hatchback
Damn dude that looks sick!! good luck with the turbo hopefully the mounting and everything else turns out great.
BoostedTRD is offline   Reply With Quote
Old 10-24-2014, 04:56 PM   #16
Ryze268
Ryze268's Avatar
Thanks much, I'll be sure to update you guys with any progress I make.
Old 11-09-2014, 06:57 PM   #17
Ryze268
Ryze268's Avatar
My sandwich adaptor and oil lines arrived today. Just need a few more couplers and boost/oil pressure gauges.
Question:
1) Should I use Teflon tape on everything I have to screw in (to avoid leaks)?
2) How does the factory 1NZ turbo Vitz read boost?
3) What kind of oil do you guys recommend?
Old 11-09-2014, 08:21 PM   #18
KTS
KTS's Avatar
Drives: Vitz RS
1) yes you can but do it neat if you decide to as any tape that blocks a passage can be the end of a turbo or even the engine. There is a liquid thread seal that can be purchased that works good and will avoid blockages. Those couplings/fittings are designed to prevent leaks.
2) I have no idea wish I had a turbo vitz to tell you. You wud need at least a 2 bar map sensor (1 bar vacuum and 1 bar boost) wired to your management of choice and the clip the MAF sensor voltage at atmospheric pressure.
3) Use the same oil you usually use. Turbos are designed to be used with a wide variety of oils. What is more important is using the correct oil restrictor for your turbo. Too much or too little oil pressure to a turbo is what destroys the turbo. Your turbo looks like a chine turbo therefore you should prime the oil system before starting ( unplug all coils and injectors) and tumble the car with the oil return disconnected. Then start the car only when oil drains from the oil return line. This will ensure that the turbo is receiving oil. When I had a chine T2860 turbo I had a radiator repair place weld close the oil supply banjo bolt and then I re-drilled a smaller hole to limit oil pressure to the turbo. Garrett website indicates the oil restrictor size for journal and ball bearing turbos. Or contact the turbo supplier and ask them if a restrictor is needed then ask them again lol.
Sorry I think I got carried away. I just miss having a turbo charged car and remembering all the little projects I had to do.
KTS is offline   Reply With Quote
Quick question for those who know................. NEexpat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 11-21-2012 02:38 PM
Quick question StephenMenace Third Gen Yaris General Discussion 4 01-27-2012 08:20 AM
Just a quick Oil question mr_miles DIY / Maintenance / Service 19 11-05-2011 12:31 AM
Quick Oil Question nickhjort Performance Modifications 5 04-27-2010 09:51 AM
ZPI Turbo question? localnet Forced Induction Forum 15 06-29-2007 07:06 AM
