Old 12-09-2014, 05:34 PM   #1
Eduardo_mty
2015 , Rear Fog Light
This car was made in France , so I guess that if you are ready for use the rear fog light ,
anyone know what the cable or fuse should I use
Eduardo_mty is offline   Reply With Quote
Old 12-10-2014, 12:05 AM   #2
Eduardo_mty
Wich is the wire fog light wire?
Old 12-10-2014, 09:53 PM   #3
Not all are made with the support for the rear fog lights. There is a relay integrated into the body ECU for driving the rear fog if it is. The relay is buried deep in body ECU, so you can't actually look to see if it is present.
There is a separate fuse for the rear fog in the under dash fuse panel: 7.5A FOG RR
With the fuse present and the rear fog switch on (or it will also automatically turn on if the front fog switch is on) power will be applied to the green wire in pin 3 of connector 3D (I believe I posted the diagram of that connector in one of your other threads).
Old 01-04-2015, 05:19 PM   #4
Eduardo_mty
Thank you CTScott.. The driver interior fuse box, do not show a fog RR.
Old 01-04-2015, 07:51 PM   #5
In that case, there is likely a significant harness change for the ones with rear fogs.
Old 01-05-2015, 08:57 AM   #6
Yaris Blue
Drives: 2010 Blue Yaris LB
I have a 2010 LB Yaris. I found that when I pulled the fuse to disable the AC that the rear fog button would no longer light. The rear fog still worked but no indicator light.
Yaris Blue is offline   Reply With Quote
Old 01-06-2015, 01:53 PM   #7
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
It seems that the gen 2 is closer related to the gen 3 than the gen 1, but I doubt that this allows any serious assumptions about the gen 3's wiring ;)
I drive, therefore I am.
dj92 is offline   Reply With Quote
Old 01-06-2015, 07:03 PM   #8
He is talking about rear fog lights, not the rear defogger...
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Any PICS of Fog Light SWITCH Location?? TRDMarty General Yaris / Vitz Discussion 7 05-29-2012 04:00 PM
Fog light jumping question netz2008 DIY / Maintenance / Service 1 01-16-2012 10:55 PM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 05:24 PM
