![]() Drives: 2007 Yaris HB Join Date: Dec 2011
Troubleshooting RCAs
So I have 2 amps: one for the 4 cabin speakers (2 front, 2 rear) and one for the sub.
I upgraded the sub amp recently (swapped to higher watts); and when I tested it out, there was no sound from the sub. The cabin speakers were fine. Light on the amp comes on (indicating power) and I measured ~12.5v (engine off) across the power-ground inputs. With power to the amp, I pulled the RCAs coming from the HU and inserted a pair coming off my phone (headphone jack to RCA). Sound could be heard from the sub. I really doubt the RCA cables are bad, since they were working before with the previous sub amp. So do I need a new head unit or is there something else I can try? Opinions/comments welcomed!! |
Make sure the Sub level is turned up if it's hooked up to a sub output on the deck.
Your cables could have gone bad from pulling out the old amp.
So its not the cables...
HU has 3 sets of RCA outputs: Front, Rear, Sub. I unplugged the Rear set and plugged in the pair from the sub amp. I got sound! So now its definitely the HU Sub RCA outputs that are bad. Know how to fix? |
so you made sure the level is turned up on the sub output?
Did you try to put back your old amp?
D.
. CLA 250, 4MATIC |
Yeah, I made sure the sub level output on the HU was greater than 1 (range is 0-6).
HU is JVC Arsenal KD-A625. No, I didn't try the old amp. |
| Help troubleshooting LED mirror turn signal | JudgeM | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 01-04-2014 12:35 AM |
| Need CLT troubleshooting advice | gboezio | DIY / Maintenance / Service | 5 | 07-18-2013 09:49 PM |
| Troubleshooting Mix Bag! | ras3448 | Third Gen Yaris General Discussion | 0 | 08-17-2011 02:49 AM |
| New Knu RCA'S & Speaker Wire....Wow (Knu is no joke) | The Architect | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 01-02-2010 11:38 PM |
| Are more expensive speaker wires and rca's worth it? | raz1121 | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 12-23-2008 10:55 PM |
