Old 02-28-2015, 03:32 PM   #1
caaront
Drives: 2007 Yaris sedan, red
Running an amp wire thru the firewall, where?
Can't find a place, any suggestions?
Thanks
caaront is offline   Reply With Quote
Old 02-28-2015, 03:45 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
driver side. same place where the throttle cable goes through. The gommet have a hole where you can cut open to fish a 0/1 AWG though.
Old 02-28-2015, 03:49 PM   #3
caaront
Got a wire through but can't see it, when my cousin gets here we will locate it together.
Got quite a bit done already, should be done with the stereo system after this evening.
CD/DVD and powered 10" sub.
Can't wait to hear it.
Old 02-28-2015, 03:54 PM   #4
caaront
Nope, didn't go through, totally lost.
Old 02-28-2015, 03:55 PM   #5
IllusionX
Push all the way until you can anymore. Then you will find your cable hanging high up if you look under the dash, way up. You actually have to lay on the floor and look.
Old 02-28-2015, 04:06 PM   #6
caaront
Can't find it in the engine bay
Old 02-28-2015, 04:09 PM   #7
caaront
Where do I push it through the firewall from under the hood
Old 02-28-2015, 04:10 PM   #8
caaront
I see where the wire goes through under the dash but not on the other side of firewall
Old 02-28-2015, 04:15 PM   #9
caaront
I see only 1 place wires run through by the. br ake fluid reservoir, is that it.
Old 02-28-2015, 06:37 PM   #10
caaront
Got it woo hoo.
Sounds great.
The reason for the brain part is it is below freezing here and I was in almost frozen water and have not felt my toes in hours.
Thanks for the help.
Help choosing sub Duckywitbigfeetz In Car Entertainment + Electronics (audio / video / alarm) 40 03-31-2010 12:06 PM
Running Firewall Power Wires for subwoofer MacMaster761 In Car Entertainment + Electronics (audio / video / alarm) 17 03-06-2010 03:04 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
