Old 02-18-2015, 07:13 PM   #1
kvhkelly
Drives: 2008 Yaris
Burned out clutch
2008 Yaris. Bought new. Didn't start on day 5 and the clutch wouldn't engage. Took it back to have it fixed and was told that the clutch wouldn't engage if the car mats were in. That didn't fix it. Dealer made an adjustment, but it still wouldn't engage unless the clutch was dead mashed into the floor. The clutch wore out at 88k. Good driver; driven stick many years with no other problems. Anyone else had clutch problems from the start like this????
kvhkelly is offline   Reply With Quote
Old 02-18-2015, 07:28 PM   #2
sheekeebut
Minimalist
Drives: 07 silver sedan
Not at all. Some have reported some clutch chatter when new, rolled off the lot, but most complain that it's caused more by technician incontinence than product defect. Easily resolved with a quick bleed.
sheekeebut is offline   Reply With Quote
Old 02-19-2015, 02:03 AM   #3
nookandcrannycar
Nope. Original clutch still working in my '07 at over 300,000 miles.
Old 02-19-2015, 05:40 AM   #4
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I've driven 14 cars with manual transmissions over the years (2 of those I put over 100,000 miles on) and my Yaris is the ONLY car that needed the clutch replaced. It happened last week with only 33,000 miles on it. I know how to drive a clutch and I don't ride it, nor do I keep it pushed in at stoplights. If you do a search of Toyota clutch replacements other than Yaris, there seem to be quite a few. I filed a dispute with Toyota asking for reimbursement but haven't heard back yet.
Mine wasn't from the start though. I did notice some chatter the past 6 months when we'd had rain or high humidity but that quickly went away.
DebbyM46227 is offline   Reply With Quote
Old 02-19-2015, 10:47 AM   #5
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Impressive. No garage pics?
Digging the Carmine Red. Don't see many of those around here. Please keep us updated on the results of your dispute.
I've got 57k in my '07 and the clutch feels the way it did when I got her 8 yrs ago. Having said that, I did notice a huge difference in terms of how the clutch felt, where it grabbed and the ratio of gas to clutch when coming over to the Yaris from my Civic. I thought I'd end up burning through it quickly because it took some real getting used to.
Old 02-19-2015, 12:16 PM   #6
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
My clutch was replaced under warranty at about 23,000 miles. I had them put the TRD unit in. Now over 84,000 miles and no issues. That being said, the clutch in my xB went out at 33,000 miles (same powertrain). They had to replace the thing twice before I ended up trading it in on my Yaris.
Old 02-19-2015, 12:19 PM   #7
ern-diz
ern-diz's Avatar
Wow
Old 02-19-2015, 01:13 PM   #8
edmscan
edmscan's Avatar
Drives: 2020 Corolla
I went thru a clutch in my Toyota Tercel once .. but the Yaris is fine. 185,000 km (111,000 miles).
edmscan is offline   Reply With Quote
Old 02-22-2015, 04:22 PM   #9
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I'm at the same mileage with my 08 sedan and have no clutch problems to date.
Have Yaris will travel..
Old 02-19-2015, 01:59 PM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
My echo's clutch was slipping at 21k km which was replaced under warranty, and again around 42k km. I traded it for the Yaris at 46k km.
Old 02-19-2015, 05:45 PM   #11
canadian deacon
Drives: 2014 yaris 5dr
I replaced my clutch from my 05 at 290,000 km. It was still within spec, but just.
canadian deacon is offline   Reply With Quote
Old 02-19-2015, 09:23 PM   #12
nookandcrannycar
There is a 'clutch test' one can perform on flat ground...posted somewhere here on the site. I always forget what to do, so have to look it up each time. Last time I performed the test was probably just under 10,000 miles ago....no indication from the test that it needed replacing.
Old 02-23-2015, 08:24 AM   #13
El Kapitan
Senior Veteran
Drives: 2007 5 door hatchback
145,000 kms, the previous owner of my car had to have the clutch replaced, but he was a terrible clutch rider.
El Kapitan is offline   Reply With Quote
Old 02-23-2015, 08:35 AM   #14
bronsin
bronsin's Avatar
Given the throttle hesitation on the throttle by wire Yaris engine (as opposed to the throttle by cable ECHO) Im not suprised people who normally dont trash clutches are having issues...
Old 02-24-2015, 09:55 PM   #15
nookandcrannycar
Re the Yaris, I wonder why Toyota didn't just leave well enough alone (leave it as throttle by cable like the ECHO) ? Did some other change make the change to drive by wire necessary ?
Old 02-25-2015, 06:05 AM   #16
bronsin
bronsin's Avatar
Probably cheaper as a lot of hardware is eliminated.
My initial reaction to the unacceptable throttle response of my 09 was to take it back to the dealer and say "FIX IT!"
But I had observed on this excellent forum the issue before buying and realized thats just how it is. I didnt think it would be as bad as it was and cant BELIEVE Toyota is getting away with it.
Old 02-25-2015, 07:24 AM   #17
roxy1
Drives: 2014 yaris 5 speed
geez, the Yaris seems to be having a lot of clutch problems between 150,000 and 200,000 miles.
seems like a defect or Toyota is really going downhill
seriously, ive spent more time than I ever should on Toyota Nation, and id say a definite attribute to Toyota clutches is they will go a long, long time before needing replaced. sure there are isolated cases, but overall the pattern of longevity is there.
I replaced the clutch in my first corolla at 202,000 miles (though it could have been done a little earlier). My dads camry had a clutch replaced about a year previous to that at 178,000 miles.
roxy1 is offline   Reply With Quote
Old 02-24-2015, 11:24 PM   #18
Echo86
Drives: 2003 Toyota Echo
Replaced the clutch at 250 000 kms. Drove it since 50 000. Don't be desperate to get home, driving through 8 inches of snow will destroy a clutch (melted the clutch springs and wore the pad beyond the metal. Wish I took pics). Great little car. Welded her exhaust back together today.
Echo86 is offline   Reply With Quote
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
