Old 04-12-2014, 12:20 PM   #1
Radou
Radou's Avatar
Drives: yaris 09 ncp91
Blitz supercharger rebuild
hey guys anyone here have already done a rebuild on his blitz sc i need to know how to take appart these two shaft i take this picture here on the forum but no response
thanks a lot guys !!
Radou is offline   Reply With Quote
Old 04-12-2014, 12:56 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey Radou,
Probably no one knows because they've never taken one apart before.
Greg
Old 04-12-2014, 12:57 PM   #3
Radou
Radou's Avatar
Yeah i know
Envoyé de mon SGH-I747M en utilisant Tapatalk
Old 04-12-2014, 02:40 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
yea your best bet is to call blitz and ask them.
Colin Chapman disciple
Old 04-12-2014, 02:47 PM   #5
Radou
Radou's Avatar
:S
Old 04-12-2014, 11:06 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I found some partial pics of someone else doing a rebuild. There's a few more in that "bucket".
Assuming that ours uses a bolt-and-taper, you remove the bolt from the center of the clutch, then pull the "armature assembly" off the face of the "rotor" (see the installation link below). You may need a gear puller for that.
There are also some .pdf mechanical drawings on Ogura's website:
http://www.ogura-clutch.com/download...tem=427&type=1
You may also be able to reverse the install instructions:
http://www.ogura-clutch.com/products...p-by-step.html
...and google image search comes through to provide the original forum thread for those pictures:
http://www.scionlife.com/forums/showthread.php?t=125535
Old 04-12-2014, 11:39 PM   #7
Radou
Radou's Avatar
Thanx
Old 04-12-2014, 11:59 PM   #8
CrankyOldMan
I have to confess, I only know about this stuff because I'm secretly planning to boost a 2ZR-FE with my Blitz one day. =)
http://www.ogura-clutch.com/download...tem=793&type=1
Old 04-13-2014, 10:50 AM   #9
CrankyOldMan
For reference, our kit is based on the Ogura TX07 pump.
http://www.ogura-clutch.com/download...tem=635&type=1
Old 04-13-2014, 02:02 PM   #10
I'd like to know if that works at all. It's hard enough just ordering the darn things.
Old 04-07-2015, 10:48 AM   #11
CrankyOldMan
So I picked up this kit for spares and tinkering, but have hit the same wall as Radou. I.e. I can't get the shaft apart. I tried a small slide hammer yesterday with no result. Granted I didn't have the whole thing held down very well, but there was no appreciable change to the gaps in the shaft.
The part that has me completely stymied is that there is a split in the shaft, just below where the snout bearing sits. This leads me to believe that there is something else going on between the OEM shaft (line illustration) and the Blitz shaft. Potentially, there is a threaded fastener holding the Blitz shaft to the OEM. That would explain why the slide hammer isn't doing much on that end, but doesn't explain what's happening at the split. Could be splined, could be a press-fit, could be threaded as well. I doubt even an X-ray machine would help here, since it's all steel.
I've tried to contact the original poster of the top image (Will-I-Am) but haven't heard back. His forum stats show activity as recently as last week, so I assume he's still around from time to time.
Old 04-07-2015, 01:48 PM   #12
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Seeing that the left side has a hex and is threaded, is there a need to remove the part
you're questioning about? If it is removable, it looks like it may have been press-fitted
though I wouldn't know either. I don't see the spline. Is there a key way somewhere on
that thing?
From the images in this thread, I could only guess that that cylindrical part is part of the
shaft or that it was press-fitted.
Old 04-07-2015, 01:57 PM   #13
CrankyOldMan
The input shaft rotor is on the other side of the body from the nut. I can't get the shaft out of the bearing because the nut is now captive. I assume that there's a press fit for the spline, but it's not responding to pulling force alone. Hence my concern that there's a threaded fastener hiding in there.
The line drawing in the bottom left corner is from the Ogura dimensioned drawing of the base TX07. It indicates a spline and a female thread--just like on the end of the shaft extension. I'll see if maybe I can do some CAD models of what I think is inside.
Old 04-07-2015, 06:23 PM   #14
CrankyOldMan
Took it to the machine shop at the uni, hit it with a torch, fell right apart. Pics to follow.
Old 04-07-2015, 06:29 PM   #15
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Press fitted, huh?
How are you going to get that back to press fit nicely again?
Old 04-07-2015, 08:32 PM   #16
CrankyOldMan
Press fitted, huh?
It was a learning process, as much as anything, so I'm not too worried about getting it back to its original state.
Turns out the damned thing is splined all the way through, as well as having a liberal coating of threadlock. If you're so inclined to rebuild your kit, I would advise a bit more caution than I used--the acetylene torch was good and blue, and was applied directly to the coupler for almost a minute. You can probably get away with propane/butane, just try not to make the metal change color--that means you're annealing (softening) it.
Old 04-08-2015, 01:22 PM   #17
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Wow! Splines all the way through that bore! I guess Ogura didn't want anyone to
dismantle their work! The extreme heat must've broken up the threadlock. Perhaps you
can start your own blitz supercharger repair shop by now? :)
Old 04-08-2015, 06:57 PM   #18
I spoke with Ogura recently about parts and they don't sell any parts, so it looks like they intended them to not be repaired.
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 06:49 AM
Blitz Supercharger w/ fixed pulley and supporting modds blacksandiegovitz Items for Sale by private party 25 10-11-2011 01:45 AM
Anyone using the Blitz Supercharger? revolution Forced Induction Forum 2 11-20-2010 06:57 PM
Blitz Supercharger and AEM Water Methanol Kit Morgan Items for Sale by private party 18 01-25-2010 11:54 PM
blitz supercharger!!! djgab101 Australia 4 11-20-2008 06:06 AM
