Old 09-28-2012, 03:10 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Toyota OEM Camber Bolt Part #
Hi All,
thought this would be useful for those looking for a OEM option on adding some negative camber, IMO which this car deseperately needs. The most aggressive negative camber Toyota offers is with part # 90109-15004.. I had a tough time getting this print out as most Toyota parts people have the intelligence of concrete cinder blocks. When installing these I would recommend loading your suspension with a floor jack before tightening.
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 09-28-2012, 03:25 PM   #2
DeathBeard
DeathBeard's Avatar
when I get some coilovers, most likely megans I will definately be slotting the top hole
Proverbs 16:9
Old 11-20-2012, 07:42 PM   #3
DeathBeard
DeathBeard's Avatar
Toyota part number 90109-15004 on top, this will give you nearly 2 deg of neg reliably, it's an oem part! And they are only $4 each!
Proverbs 16:9
Old 11-20-2012, 08:02 PM   #4
NJ Drive
Drives: 2012 Yaris SE
I'm using one 90109-15004 per side, on stock springs, and was able to get anywhere between -1.3° to -1.6°.
-2.0° would be a bit of a stretch.
NJ Drive is offline   Reply With Quote
Old 11-21-2012, 12:00 AM   #5
DeathBeard
DeathBeard's Avatar
-1.3 seems strangely low for this bolt..My first reading with these was -1.7, after messing around with it and loading the strut with a floor jack I was able to get -1.9, I would consider that pretty close to -2.0, right??
Proverbs 16:9
Old 11-21-2012, 05:51 PM   #6
DeathBeard
DeathBeard's Avatar
took my measurements again today and the front is -1.9
Proverbs 16:9
Old 11-21-2012, 06:01 PM   #7
DeathBeard
DeathBeard's Avatar
front no longer rubs
Proverbs 16:9
Old 11-21-2012, 08:09 PM   #8
NJ Drive
You are not on stock springs and/or stock ride height, correct?
Old 11-21-2012, 08:21 PM   #9
DeathBeard
DeathBeard's Avatar
ride height does not effect camber w/ mcpherson strut design, only double wishbone does
Proverbs 16:9
Old 11-21-2012, 08:23 PM   #10
Jason@SportsCar
no but macphesron strut is not depedant on that, only double wishbone is
Not entirely true... The lower arm is not flat at stock ride height, and the car will gain camber to a point as you lower it and the arm flattens out.
Old 11-21-2012, 09:51 PM   #11
DeathBeard
DeathBeard's Avatar
I see your point Jason, I hadn't thought of the lower arm angle...I was visualizing only camber plates or crash bolts
Proverbs 16:9
Old 05-01-2015, 02:55 AM   #12
Thebigwicks
Drives: 2008 lowered yaris on 17's
Just picked up a set and hadn't really go a chance to fool with them yet. So do you just install them on the top hole and that's all? Still don't understand how they work.
Thebigwicks is offline   Reply With Quote
Old 05-01-2015, 12:18 PM   #13
Caramanos2000
Drives: 2012 Yaris 5dr Hatch
Got these today for $8 at the stealership. Anyways they work by letting you push the wheel in at the top. This happens because the outside diameter is smaller and thereby gives you some "play room".
Caramanos2000 is offline   Reply With Quote
Old 05-01-2015, 12:56 PM   #14
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The stock bolts should be the ones without dots. You replace both bolts with the new ones (3 dots) and tilt the hub as far in as you can, then snug the nuts over them. I suggest taking it to an alignment shop and have them set it as negative as possible, with the castor and toe set to nominal if possible.
The chart below shows how to mix and match OEM bolts to get a desired camber from a known configuration or offset. The green box is the default OEM setup. If you want to get -1.5°, you need set F, which is 2x 90109-15004.
Old 05-01-2015, 05:16 PM   #15
Thebigwicks
Okay, that makes sense. I picked up part number 90109-15004 and I have never changed any bolts. So it's safe to say that I have the regular or own setup still unless there was variation from year to year. I plan on installing the bolts on the top holes of each side. Sound about right?
Old 05-01-2015, 05:45 PM   #16
CrankyOldMan
For maximum camber, you use them in the top and bottom. I don't see the combination you're suggesting in the tables, so it's either redundant with another combo or does very little.
Old 05-05-2015, 01:06 AM   #17
Thebigwicks
Ill mess with them tomorrow and post my results. just have to figure out how to measure camber correctly now. Ill get an alignment so maybe ill just take the readings from there...
Old 05-07-2015, 12:46 AM   #18
Ben_
Drives: 2010 Yaris Hatch
I'm starting to look at using OE bolts for camber for racing application. I would like -3 using OE bolts and/or other procedures documented by the OE (as per scca rules) which could be making the mounting holes larger. My suspension is stock otherwise
Ben_ is offline   Reply With Quote
FS: OEM Toyota Vios Turbo Kit CTScott Items for Sale by private party 24 07-31-2011 10:12 AM
Ultimate yaris part out, aftermarket and OEM yaris rs Items for Sale by private party 25 06-20-2011 01:43 PM
FS: OEM Toyota Yaris Roof Rack with Thule Fairing 33OH Items for Sale by private party 18 03-31-2011 05:14 PM
A few OEM 2008 Toyota Yaris parts white_rice Canada 0 03-20-2010 06:23 PM
