![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
Installing struts in my yaris
Hi I took plenty of pictures. This is how I removed and replaced my struts. I wish I would have bought KYB quick struts as compress the springs and pressing in near bearings toke alot of time. 2007 yaris w/ 65K. Yes it was early but I can feel a big improvement!
You can remove outer bolts and leave metal cowl in place and slide on in underneath it!
I left all washer hoses connected
Lfting with a hein wrener 2 ton jack. Jack stands at the sills w/ slots for the pinch welds. Had to have the front wheels on 2x lumber to fit hein Werner jack under car.
impact w/ a 17mm impact socket on upper end link
removing lower link from swaybar. i bought moogs as rteplacements. hint: if really rusty use a 7/32 asa a 6mm does not fit a corroded allen hole. Wrench is a super long sk g pro 17x19 ratchetimg spline wrench. plenty of kroil oil used. These slowly came off even with all that leverage.upper link to strut was impacted out. lowers were removed w/ allen and wrench
uppers were eventually impacted out. allen cammed out. vice grips came into play
Big armstrong 12-994 18 inch long locking flex head 1.2 drive ratchet on the nut. A big proto 17x19 on the bolt. These are on tight. Lower stut mount bolts and nuts are 19mm. Since I used 1/2 drive i didnt need a deep socket for nut.
a fter I broke nut loose,I switched from big ratchet to the sk g pro 17x19 ratcheting wrench
spring compressor time! I used this one: http://www.amazon.com/s/ref=nb_sb_no...words=atd+7550
#14 |
when spring was compressed enough not to be touching strut cover, I zipped the 17mm now off w/ a 17mm deep impact socket driven by a Milwaukee v18 impact wrench.
#15 |
I drove bearing out of strut plate w/ a sk punch and ballpeen hammer! One tap out! Put upside down like this in vice. Put punch in hole.
#16 |
top view
#17 |
new vs old
#18 |
hey look no spring or boot
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| Yaris vs Celica | jesh462 | New YARIS Purchase Forum | 11 | 10-18-2012 11:49 PM |
