![]() Drives: 2007 Toyota Yaris sedan Join Date: May 2015
Help! sheared bolt on engine
While trying to replace the thermostat on my 2007 Yaris sedan, I overtightened the nuts and the bolt on the engine sheared off. How do get the broken bolt out of the engine? Can it be removed from the outside by heating it with a torch and using vise grips on the remaining bolt stub?
Or, can I weld a new bolt onto the stub and add some washers?
If that much is left, you should be able to get it out with vice grips.
Those are only like 6.6ft/lb. Just snugged basically. So in order to break them, they were WAY too tight.
#5 | ||
Correct - Those are threaded studs, so on the end they have a tiny external torx head that you use a "E#" socket to remove.
#7 | |
![]() I very seldom use a TW in 45 years of wrenching, but when I do, its my circa 1970 Sears beam type with a pointer rod that twists and points at a scale. ![]() My Dad bought a factory rebuilt short block for a 69 Beetle he bought for me to fix with a blown engine. ($400) The first thing I did was drop a washer down the distributor drive shaft hole. I started taking the engine apart to get the washer. After 10 minutes of that my friend Peter showed up, having heard about the rebuilt engine we were getting and wanting to see me put it in. When he saw me taking it apart he laughed and said "Here help me pick it up. Now turn it upside down and shake it." The washer fell out!
#8 | |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| Engine Delayed Start - Toyota 1NZ-FE 1.5L | SL Runner | General Yaris / Vitz Discussion | 9 | 07-23-2011 03:13 PM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
