Drives: yaris hatchback 2007 Join Date: Aug 2017
exhaust gasket
This is an easy fix to a potential costly one. The manifold to exhaust pipe bolts are usually, severely rusted. I used PB Blaster, heat, a 120 psi impact tool and the bolts did not budge and thankfully, they did not break which would have been a headache.
SOLUTION: with a large thick screwdriver spread the flanges apart to maximum and place anything thick enough to maintain the space. Use long hemostats or something that can remove the old gasket material. Purchase high temp exhaust rope, braided is better than twisted, they are available in 1000 and 1800 degree temperature ratings, some hardware stores carry them in 1/4 and 1/2 inch diameters. Thread rope around pipe tightly several times, cut and remove device that maintained the opening, the flanges will close perfectly and no more noise. TIME: 15 minute job. COST: 6.59 before taxes Last edited by chick magnet; 08-13-2017 at 12:16 PM. |
Exhaust stainless nuts bolts gasket
On Tercel and Corrolla I used, from hardware store, 3/8 stainless nuts/bolts on all the exhaust system flanges. (9/16" or 14mmwrench or 6 point sockets fine for nut and bolt.) Stainless washers are fine too.
(People use tools including hacksaw blades; air chisel; hammer and chisel; and torch to remove the badly rusted fasteners.) |
If you can get the nut cherry red it'll come out like it was lubbed.
#4 | |
Heat gun will not achieve anything close. Butane+o2 torche to get it red, and a ratchet will do the trick. No need of air impact. Sent from my SM-G930W8 using Tapatalk |
| Exhaust Manifold to Pipe Donut Gasket | yarisinpa | DIY / Maintenance / Service | 1 | 06-29-2017 03:35 AM |
| Front Exhaust Gasket Replacement | tmontague | DIY / Maintenance / Service | 6 | 03-25-2015 10:00 PM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Enkei's and Dunlops + Medalion Touring Exhaust | 2manywheels | Items for Sale by private party | 40 | 04-04-2011 05:01 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
