Clutch replacement. dealer or private Mechanic?
08 yaris sedan with 200K kms, manual tranny, i suspect its time for clutch replacement as pulling away from a stop is getting almost impossible to do without the cars shuddering/juddering, Wondering what a ball park $$ figure is for the job and how long it will take., also wondering if i should get the job done at my local Toyota dealer or my local private mechanic.
Thanks
Have Yaris will travel.. |
![]() ![]() Drives: 2007 toyota yaris sedan Join Date: Jun 2015
Clutch replacement is for when you have trouble getting the car to move faster on the road.
Basically if it has a hard time going past 20mph and revs more then what's going to the ground. That's when you need a new clutch. Or when you have broken the whole cage assembly. Theirs other reasons to replace the clutch but these are the only two i heard about. Is your car over revving? When car is actually suppose to be moving forward increase in speed? That's signs you might need a new clutch. Sometimes Last edited by valchrist90731; 07-21-2015 at 04:59 PM. |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
If it's shuddering on takeoff easily it's another sign and the clutches on these cars suck to begin with. Very soft feeling. If your gonna change get a stage-1. Doesn't cost much more and a world of a difference
for clutch slip u do it in high gears like 4th or 5th gear , if car revs up more than ur going then its slipping
Shuddering happens on Honda's Chevys Toyota's and many more on take off because of the driver.
Well that's what i seen and experience when other's don't know how to balance when taking off in first. Don't take offense but explain more. Shuddering? That happens ... just be more careful how or when you release the clutch? Perhaps? I could be very wrong though please explain. Release the clutch wrong a lot a cars will shudder. This was written as respectfully as possible don't get offended. I never had a car shudder more increasingly over the years and need to replace the clutch because of this. I know shuddering put the clutch down and try again?. If your struggling to go up a hill and every one is passing you might need a new clutch. Last edited by valchrist90731; 07-21-2015 at 08:15 PM. |
I have not ever had a car with such a soft clutch ever. Mine shudders on take off quite easily, then from 2nd gear up I don't use the clutch drive casually.
I wouldn't go to the dealer, gonna cost big time! I haven't had a car a car either shudder increasingly, my Yaris has been this way since I bought it. Would be good to hear others experience. Plus in over 32 years driving, I replaced a worne clutch once on a used car I bought. Previous owner was horrible with it. Other then that, I replaced clutches for performance reasons on cars that where not stock |
#7 | |
And yeah, to check for slipping find a hill (THE hill in Montreal? Mont Royal maybe ) get it in 3rd or 4th and floor it. Higher gear the better. If the engine rpms rise, and the vehicle speedo does not, you are slipping. Other indications are that the clutch engagement point in the pedal is very high.Cheers. |
#8 | |
Go for it take it to an independent shop and we will see u back fixing there fukups lol Ppl think they save money but honestly they don't who do u trust someone that knows ur car inside out or a Joe blow looking up Google lmao. Just my 2 cents on this... U get what u pay for its why I drive a Toyota 😁 Sent from my ASUS_Z00AD using Tapatalk |
#9 | |
#10 | |
And yes I do agree with u to a point but at least here in Canada Toyota is quite strick about how things are done. Also keep in mind we charge more cos of the equipment we have for that specific brand of car and all the technical resources. Sent from my ASUS_Z00AD using Tapatalk |
#11 | |
My clutch is not glazed, burnt or worn and it shudders cold especially. I'm not a hack with my three cars. If the OP does the slip test on acceleration and/or uphill and theirs no slipping then yup it's just normal for this car. |
I just think the clutch is definitely odd on a Yaris and one main reason I find is flyby wire throttle body I hate it cable is so much better I find in my opinion for better human interaction between the car and u.
My Yaris is same in the morning I just get out of first gear asap lol and do second gear rolling stops... Lol just to avoid first gear Sent from my ASUS_Z00AD using Tapatalk |
Theres no clutch slip in normal driving conditions,and i would rather not rev the hell out of the car trying to see if i can make it slip.
The shudder pulling away from a stop is recent and as i have been driving this car daily since i bought it new 8 years ago i'm suspecting something mechanical is wearing out and not my driving technique. The dealer i'm thinking of taking the car to is Spinelli in Lachine, i have bought 2 cars from this place over the last 10 years and have had no problems dealing with them. My reason for favoring the dealer is they will have the parts needed will have prior experience in doing such a job and will do the job according to factory standards,whereas my private mechanic while good and trustworthy will be doing a Yaris clutch exchange for the first time,will have to order all needed parts and will obviously not have any prior experience with this job.
We all didn't know that you where the original owner.
Plus if you want to save on ordering parts, there are many Toyota's you can order from. But ask the dealership if they can put in those toyota parts i guess. Oh and let us know how much. |
#15 | |
To the OP:
End of the day, as a customer take it to wherever you are comfortable dealing with, and trust. I always recommend finding one location and building a relationship with that shop. You need to be comfortable that they will do the job correctly, deal with it if it goes wrong, and will only sell you what you need. If you have that, stick with that shop. In regard to flat-rate I stand by my statement. Having spent ~3yrs in flat-rate dealerships and 15+yrs at independents, I have no problem saying that flat-rate is terrible for customers. Flat-rate guys tend to rush and the quality of work suffers for it. Not all flat-rate guys, or flat-rate shops are bad by any means (just as all independents are definitely not good). Just the business model sucks for customers when mechanics make $20k+/yr more by rushing/over-selling/playing games, and when front-counter people basically live off commission. There is no question that dealerships know their cars better since you see the same ones all the time. I knew damn near every fastener of every common vehicle in the line while I was there, as did most of the guys I worked with. It's the flat-rate that sucks as the rewards for being greedy are too high. If your dealership is good, great! Keep doing what you are doing. But from my experience, on average most dealers will cost more and gain the customer less. |
#17 | |
On the other hand for not much more money the dealer gets my vote. Although I expect his price will be shocking! Actually the real choice in my view is to have the car repaired by whoever and then NOT SELL IT! Theres lots of life left in it. Although I see you live in Canada where winters are harsh and the roads well salted...
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2013
I'm having the same issues with my 07 sedan at 153k miles. Shuddering when blending throttle and clutch in 1st gear. Wicked annoying.
Sent from my iPhone using Tapatalk |
| compensation from dealer | 08blackyari | General Yaris / Vitz Discussion | 8 | 09-02-2010 12:05 AM |
| Service at Toyota local dealer | beZzZ | DIY / Maintenance / Service | 22 | 05-07-2010 08:23 PM |
| 60K Service by Dealer or Independent Mechanic? | tomato | General Yaris / Vitz Discussion | 33 | 01-19-2010 07:42 PM |
| Someone Please Help With SET & Local Dealer Nightmare! | sanityassassinv2 | General Yaris / Vitz Discussion | 32 | 11-26-2008 12:32 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 12:34 PM |
