Old 08-18-2015, 05:53 PM   #1
tmontague
tmontague's Avatar
wheel size with lowering springs
I've looked through the stickies but I cannot seem o find info regarding the following size and lowering springs.
I currently have MI lowering spring (-1.8" F&R)
I am going to be purchasing 15" diameter wheels by 7" wide and 38 offset. I plan on running my stock 15" tires on them as they still have a ton of life left. Once they wear out then I'll go with a similar sized tire but a bit wider.
I'm wondering will those rims fit my Yaris sedan with the MI lowering springs. I do want a closer look to the body but I don't need it so close that it's rubbing and causing issues.
Anyone on here have a similar set up or know if it will work? I measured and the offset should fit without a problem but I don't know how the wider rim will effect the fit
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 04:29 AM
Need some feedback on aftermarket lowering springs? Syroyizhka General Yaris / Vitz Discussion 13 08-27-2011 02:06 AM
TRD Lowering Springs. Alpha300 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 08-23-2011 12:36 AM
KSPORT GT vs. Tanabe DF210 Lowering Springs bad_bwoy007 General Yaris / Vitz Discussion 1 04-12-2011 02:01 PM
Factory Lowering Springs + MAX Wheels? What are the options? bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-24-2006 09:10 PM
