Old 06-03-2017, 02:55 PM   #1
SIRAY2
SIRAY2's Avatar
Drives: 2010 GRAY 4DR SEDAN
Tail light parking light & license plate stop working
Hi Guys,
My driver side headlight became dimmer, tried to DIY it by adding an extra ground wire...didn't work but lost my tail light, park light and license plate light in the process..I may have touch a + wire, anyway, I Found that my driver side fuse went bad so replaced it and my HL are OK. I still don't have my tail lights, park lights and license plate lights..my break lights, Dash indicators, cluster lights, signal light still works. Does anyone know where the tail light relay is located? This will be my next DIY check
Thanks a lot
Bob
Siray2
SIRAY2 is offline   Reply With Quote
Old 06-03-2017, 02:59 PM   #2
SIRAY2
SIRAY2's Avatar
Hi Guys,
My driver side headlight became dimmer, tried to DIY it by adding an extra ground wire...didn't work but lost my tail light, park light and license plate light in the process..I may have touch a + wire, anyway, I Found that my driver side fuse went bad so replaced it and my HL are OK. I still don't have my tail lights, park lights and license plate lights..my break lights, Dash indicators, cluster lights, signal light still works. Does anyone know where the tail light relay is located? This will be my next DIY check. Can anyone with this experience give me a heads up..I sincerely appreciate all.
Thanks a lot
Bob
Siray2
2010 4dr sedan
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 03:03 PM
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 08:28 AM
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
