![]() Drives: 08 yaris sedan Join Date: Sep 2015
08 Yaris Auto Sedan. Pass side motor mount replacement question
How do I replace this? I tried already braced engine and all. Is there a bolt underneath or something I'm missing? Any and all help much thankful for...
Keith |
Yes, you are correct, there is a bolt underneath the bracket that goes across the the engine.
Support the motor with a piece of wood on a jack under the oil pan. Remove the 2 bolts (14mm?) from the top on the bracket reaching to the engine. Remove the 3 bolts holding the mount to the body. If you have a/c then remove the 10mm bolt that holds the a/c line down against the mount. Use a long extender a get underneath the car to remove it. With the head lamp you will see the bolt head. It I what makes the whole job a pita but once your new mount is in you'll enjoy t smoother idle.
Did the rear cuz of the clunk in my wife's car tonight. What a pain. Got it done though and no more clunk or vibration between the two new mounts!!!
Still kinda has vibration after the rear mount and the pass side one. Will doing the engine/tranny mount help? Can't hurt right?
If the others needed doing and you're still noticing some vibration then yes definitely change all 3 of them. The trans mount is easy to do
BTW, how'd you find the rear mount attached to the subframe was to remove? The reason I ask is because on my Echo it is virtually impossible without removal of the subframe. It took me about 4-5 hrs to do because of how hard it was to install a bolt in a blind spot while trying to mve an engine to alllow it to match up.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
