Old 10-28-2015, 11:52 PM   #1
Sollexe
Canadian
Sollexe's Avatar
Drives: 2006 yaris ce
Rough idle after disconnecting battery
What is the best procedure to relearn the ecu after disconnecting the negative terminal. My idle has gone down to just above a stall and the valve timing doesn't sound good at all. Is putting the key in the on position prior to starting the car any help after reconnecting the terminal? Or should I just drive the car normally x amount of km, till the issues resolve themselves?
Thank you,
Sollexe is offline   Reply With Quote
Old 10-29-2015, 12:08 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
It should settle after a while.
Sent from my A0001 using Tapatalk
Old 10-29-2015, 08:34 AM   #3
tmontague
tmontague's Avatar
Drive a mix of highway/city at various speeds. After approx 100km the ecu will relearn and everything should smooth out
Old 10-29-2015, 11:49 AM   #4
Sollexe
Canadian
Sollexe's Avatar
Looks like I'm going on a little road trip today!
Vibration on idle & rough start Murtaza_murti DIY / Maintenance / Service 25 08-15-2015 01:58 PM
Engine Control Module Code and Rough Idle rks171 DIY / Maintenance / Service 4 05-13-2015 11:47 PM
rough idle.... dindy Third Gen Yaris General Discussion 5 06-12-2013 01:48 PM
Need advice/ help for rough idle lilj4321 DIY / Maintenance / Service 2 08-28-2012 03:39 PM
