![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
Lining up the head lights '09
Anyone? Is anybody still out there?
For the sedan the adjuster is inboard and below of the headlight bulb. In your first picture it is the device just below the grey connector.
I prefer this...https://www.youtube.com/watch?v=NP0mQeLWCCo Patients sometimes on this forum is needed...but you will get a response....usually, as in this case, from the master...CTScott. |
#5 | |
From your reply it looks like I could get to it easier, if I unplug that plug in the first pic. Would you say that the adjustment screw, is fairly easy to access? |
#6 | |
Hm? Put a Philips head screw driver in the hole. That's the adjuster for height. There are no horizontal adjustments AFAIK. If you look down there, you will see it, it can also be adjusted with a hex wrench.
uploadfromtaptalk1445528209866.jpg Sent from my A0001 using Tapatalk |
#8 | |
#9 | |
And with it i was able to adjust the lights. Thanks again |
#10 | |
That said, I noticed your reply says something totally different than his. You say its that one with the washer looking head, he says it those others. For me, the ones he said turned out to be the correct one. So is the other one for something else? |
やりすぎだ~
Here. IllusionX circled the same thing except that the part he circled, the adjusting screw, isn't visible, it's behind that plastic. So it looks like he circled those plastic tabs.
I would use the horizontal mortar lines of a brick wall to get headlight height the same . Park car on level ground about 5 feet away from side of a brick wall at night and make adjustments .
| 3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation | keiri | Third Gen Yaris General Discussion | 26 | 09-04-2020 01:01 AM |
| LED License plate lights for Yaris Sedan | YarisSedan | DIY / Maintenance / Service | 6 | 04-09-2013 05:05 PM |
| Instrument Panel goes out if I turn on my lights | ceceb | DIY / Maintenance / Service | 9 | 07-08-2010 06:56 PM |
| Solar powered High Bright LED lights replacing the fog lights | alan1828 | Canada | 10 | 05-14-2010 01:34 AM |
| Changing LED's In Projector Head Lights | whooppee777 | Cosmetic Modifications (Exterior/Interior) | 16 | 03-01-2009 03:07 PM |
