Old 04-22-2007, 01:53 AM   #1
Wow, I Got 48.57 mpg
okay, i just filled up after my Santa Cruz trip, and calculated my mpg. i got 48.57 mpg! most of that was freeway driving, but i was averaging 70 mph, hit stop and go traffic on the way out, and using the A/C. parts of the trip was downhill, so i was cruising that part in neutral. but man, that's some good mpg. lol...the best i've ever done was 50 mpg.
Old 04-22-2007, 02:12 AM   #2
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
holy snap...
nice!!!!
-- Blen
Old 04-22-2007, 02:27 AM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
Congratulations!
- Brian
Share the Road
Old 04-22-2007, 03:13 AM   #4
thank you all.
Old 04-22-2007, 03:14 AM   #5
Congratulations!
so does this confirm that i don't have DFCO? like i said, this was mostly freeway this tank...but when i did try using DFCO like you said, i ended up losing 2 mpg.
Old 04-22-2007, 03:19 AM   #6
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
If you ask me DFCO is BS anyway,because when you let off the gas your still in gear so there is a drag on the engine,so you slow down.Ive found tht giving it just enough gas to cruise(may drop mph allitle going straight,but I pick up goig down hill),or putting it in neutral,no drag there.
eco is offline   Reply With Quote
Old 04-22-2007, 03:20 AM   #7
yeah, but the DFCO concept seems valid, but i just don't think my Yaris has it. so i'll stick to putting it in neutral.
Old 04-22-2007, 05:30 PM   #8
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
thats pretty damn good!!!
falkor_99 is offline   Reply With Quote
Old 04-22-2007, 08:23 PM   #9
nebulight
Novice Hypermiler
Drives: 2007 Toyota Yaris
Send a message via AIM to nebulight
This post is pissing me off! I've tried to drive in the lower RPMs, turning off my car at lights, pumping up my tires to 50psi, DFCO, turning the car off while going downhill, you name it. And the best I was able to get was 37mpg on the highway, and I just filled up today and got 34mpg city!! What am I doing wrong?!
It's a slow start, but I'm shooting for 45mpg by summer. Best so far is 42.23mpg
nebulight is offline   Reply With Quote
Old 04-22-2007, 09:32 PM   #10
Edd
Drives: None
Wow, that's like 4.85L/100km (if I worked it out correctly)... :-) [That's using the "US gallon" not "imperial gallon" - even though they are both imperial measurements.. Jesus the world would be screwed without the metric system.]
Edd is offline   Reply With Quote
Old 04-22-2007, 09:42 PM   #11
Speedz
Will work for Yaris...
Speedz's Avatar
Drives: Yaris
Perhasp the engine havent run in yet...?
Like diesel engine can achieve the 1k per tank when the engines did about few thousands ks...
Speedz is offline   Reply With Quote
Old 04-22-2007, 11:31 PM   #12
YarisGuy
Drives: 2006 Yaris
WOW, very impressive indeed!
YarisGuy is offline   Reply With Quote
Old 04-23-2007, 01:10 AM   #13
i wouldn't turn off my car at lights. starting your takes a lot of gas, from my experiences. you probably don't have DFCO, like me. if your Yaris is a stick-shift, try coasting to a stop sign/light, and down hills (has to be at least a mile imo) in neutral. that's what i do.
Old 04-23-2007, 01:12 AM   #14
thanks.
Old 04-23-2007, 02:28 AM   #15
BailOut
BailOut's Avatar
Please be careful with the information you spread, Kaotic. As we've been over something is likely wrong with your ECU because *every* Yaris sold on *every* continent has DFCO. Yours does not appear to work correctly and it is possible that nebulight's vehicle may not be working properly, either, but to claim that you don't have DFCO is inaccurate. Have you discussed this with your dealership yet, or even performed the test I listed in the DFCO thread?
Additionally, what you said about not shutting off the ignition at stop lights is wildly inaccurate. Modern Japanese vehicles - especially Toyotas - are highly reliable and efficient. It takes just 7 seconds of the engine being off to equal the fuel used during starting back up and the wear-and-tear on the starter and other systems during turnover. Any time you can keep the engine off for more than 7 seconds you are not only saving fuel but also the wear-and-tear of your engine being in use.
If you only try to use DFCO and/or coasting on hills at least 1 mile long you will miss out on dozens of smaller opportunities to save some fuel every day.
- Brian
Share the Road
Old 04-23-2007, 02:38 AM   #16
in my experiences, turning on off the engine causes my gas gauge to lower quicker. also, aren't there at least several members here where DFCO doesn't work for them as well? and like i said, i've tried a few of those things you mentioned to test out DFCO, i just haven't tried turning off the engine while driving.
no i have not discussed this with my dealership. i'm trying not to mention any problems, as small as this, with them because i have modified my Yaris, and don't want them to say that my warranty is voided. but i can go to a different Toyota dealer, i guess. but yeah, i'm tired of dealing with problems about my car, so i'm good off of asking a dealership.
just for confirmation, can you provide me the info saying that all Yarii have DFCO?
Old 04-23-2007, 02:44 AM   #17
BailOut
BailOut's Avatar
There's no master document that shows it but it's in every white paper on the ECU that's bundled with our 1NZ-FE engine.
It's also in the white papers for the ECU that's bundled with the 1.3L engine (same ECU, slightly different programming).
Those are the only 2 engines the Yaris comes with no matter where in the world you are, so every Yaris has DFCO.
- Brian
Share the Road
Old 04-23-2007, 03:10 AM   #18
then yeah, my "DFCO" is not working properly then, like several members here.
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 08:15 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
To accurately measure MPG when should I fill back up. mgthompson General Yaris / Vitz Discussion 17 03-30-2007 10:07 PM
Rims, Tires, and MPG Pavel Olavich Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-23-2007 07:28 PM
Yaris Mpg query Vanguard General Yaris / Vitz Discussion 3 03-18-2007 09:56 AM
