![]() Drives: 2008 Yaris Join Date: Dec 2015
No lights on air conditioning switch at night
Hi, When I was driving on night, I found there are no lights on these air conditioning switch. see the photo I linked.
Is this normal? Or, those lights on these switches are broken. Because it's not quite convenient when i was driving and need to tune those switch. Thanks |
#2 | |
If the brightness of the instrument cluster lights does not change when you adjust the dimmer rheostat, then either your headlights are not on (the headlight switch needs to be on to trigger the illumination of the AC knob lights) or the dimmer rheostat is bad or unplugged.
#5 | |
Hi, Thanks for your response.
At the second I saw your comment, I went to the car and tried again. It still doesn't work and seems like the dimmer rheostat is bad or unplugged. I want to fix this, is this expensive? Or I can repair by myself? Quote:
#6 | |
For checking the rheostat you can open and remove the little storage cubby on the lower left of the dash. Once you do that you can reach in and verify that the connector is plugged in.
| -Mileage Thread- -Log your mileage, year, model, color, any problems here... | Kal-El | DIY / Maintenance / Service | 322 | 07-20-2016 11:07 AM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 07:36 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
| Finish Sedan S Intake, Paint Caliber, Air Vent Lights | jamal1984 | Performance Modifications | 9 | 03-12-2007 12:57 PM |
| Air Flow switch problem | aucorium | DIY / Maintenance / Service | 5 | 01-15-2007 05:54 PM |
