Old 07-04-2016, 08:21 PM   #1
Pinchlite
Drives: 2007 yaris HB
Direct power stereo with toggle switch
I am sick and tired of having my stereo reboot when going from acessory and starting the engine.I tried reddit car audio but they are vague in explaining how to do.Basicallly I want the radio to be able to be used without key.
I know,I know.. I could forget that radio is on and drain battery but that does not bother me.
I have lots of experience with electronics(Building racing/aerial video quadcopters) so soldering and a multi is no prob.Thanks for any help.
Old 07-05-2016, 10:26 AM   #2
ercdvs
Drives: 2010 Yaris
wouldn't you simply switch the power wire going to the radio from being 12v ACC to a constant 12v source ?
you would likely find this at the fuse panel
2010 hatchback
Fog lights, Kenwood touchscreen, backup camera
ercdvs is offline   Reply With Quote
Old 07-05-2016, 10:26 AM   #3
ercdvs
Drives: 2010 Yaris
2010 hatchback
Old 07-07-2016, 12:17 AM   #4
CoryM
Drives: 2009 5-door, 5-speed
Yep. Should be able to just cut the ACC wire and tie it into the BATT wire. I'd just do it at the back of the head unit. Not sure about fuse ratings, but should be fine.
Old 07-07-2016, 11:28 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
No, doing that will kill the battery. You can add a diode to the acc power wire and then add in a jumper wire from 12V to the acc stereo side of the diode so you don't backfeed the acc circuit.
That way you can power up the stereo without the key, but maintain factory operation with the key.
Old 07-07-2016, 11:58 PM   #6
CoryM
I wasn't very clear: cut the acc wire and leave the harness side disconnected. Then splice connector side acc wire into batt wire so both wires get power from the battery. Will work fine unless the Yaris headunit does something unusual.
Old 07-08-2016, 12:27 AM   #7
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
Hi I got tired of leaving car in storage and having my single battery go completely dead I don't like resetting all my radio functions so the best thing I did was put two odessy batterys in my lb never had it happen again I have the 2nd battery on a isolated to shut it down if I choose and anytime I have done the big 3 and ran the zero Guage wire thru out the car and I run a dc power 180 amp alternator solved any prowler shortages I had witch was very small but I do run 2 kar series 1000/1 sub amps strapped pushing 2 jL audio jl6 10" subs in a sub floor set up and a kar series 300/4 amp for all my focal separates
pennyracer is offline   Reply With Quote
Old 07-08-2016, 12:35 AM   #8
pennyracer
boydstir
pennyracer's Avatar
Last edited by pennyracer; 07-08-2016 at 12:37 AM. Reason: Picture up load correctly
Old 07-08-2016, 12:49 AM   #9
Bluevitz-rs
This will kill the battery. Even if you push the power button on the stereo to turn it off, it's still drawing power. The ACC wire is basically a remote power circuit to activate the internals of the stereo.
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 03:03 PM
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 02:59 AM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 11:51 AM
Custom Sub Enclosure (inc sub, power cap, amp) wado Items for Sale by private party 3 09-18-2006 11:53 AM
