Old 04-16-2016, 01:21 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
portable gaming system
This is my other hobby.here is a gameboy shell modded to be a Retro Pi Zero (simple) with 3 easy access usb ports and one hidden usb port.
You can see i struggled with the lettering for this, originally i was just going to remove the original lettering and add a custom graphic, but i couldn't get that to work so i had to redo it a few times and ended up making a rough spot in the case.
the notch in the top right of the battery compartment is where the hidden USB port is located.
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 11:30 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 10:34 PM
