Old 05-03-2016, 02:53 PM   #1
tmontague
tmontague's Avatar
wheel spacer Q
Anyone know how wide a spacer you can run on the front with stock lug nuts?
Old 05-03-2016, 03:38 PM   #2
Safely about 3mm, 5mm at the absolute max.
Old 05-03-2016, 04:00 PM   #3
tmontague
tmontague's Avatar
hmm, I think 10mm would be ideal for same fitment to my rear. I don't really want to install the spacers with their own studs but it looks like that may be my only option.
I'll measure what I can fit, either 15mm or 25mm it will be since I want hub centric spacers
Old 05-03-2016, 04:23 PM   #4
wheel spacer Q
My spacers are 10mm and they are hub centric. Based on my own fitment experience, 10mm in the rear gives you the same as the front.
Are you confusing lug nuts with studs. You are confusing me with your references to lug nuts.
Old 05-03-2016, 04:28 PM   #5
tmontague
tmontague's Avatar
^yup, thanks I edited it. It may be my slightly more negative camber in the front but I am much more flush in the rear then my front. I'll do some measurements tonight and post back here what the gap is.
Old 05-03-2016, 04:35 PM   #6
The narrower rear track is why most spacer installs are done in the back only. To push the rear wheels outward to sit in the wheel wells comparable to the fronts.
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Longer wheel studs for 5mm spacer? Captain Slow Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 02-09-2013 10:35 PM
FS: Sparco Wheel, Quick Release, Momo Spacer Focus_Sh1ft Items for Sale by private party 18 04-27-2011 12:36 AM
anyone knows if wheel spacer can be placed behind the hub??? jackrabbit Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-02-2010 06:41 PM
