![]() Drives: 2009 Yaris 2-door Hatchback Join Date: Jul 2016
Hello all! I just recently purchased a 2009 Toyota Yaris 2-door hatchback (78,000 miles) from a used car dealer. I'm skeptical about my purchase still because I had just bought a car from the same dealer that died in my driveway in less than a week later. I'm hoping that you guys and girls here can help me feel comfortable with my purchase.
Here's some of the things I am concerned with:
Please feel free to chime in with any thoughts or advice. Thank you all! |
#2 | |
Sent from my HTC One_M8 using Tapatalk |
#3 | |
What if the oil is fine (supposedly) and the light is still on?
then you can clear the maintenance light yourself.
1. turn on ignition 2. set odometer to trip A 3. turn off ignition 4. push and hold down odometer button (preset to trip A in step 2) 5. turn on ignition 6. keep holding trip A on until it stops flashing |
OK I will look further into resetting the light once I know with 100% certainty that it has actually been changed.
What's the likelihood of a dragging brake? I had something happen with my sable that when the brakes heated up, my calipers (I think) would expand and actually try to stop my car while I was still stepping on the gas. |
#7 | |
You stating car decelerating faster than you think it should is entirely subjective. On a 2009, there is a chance that a caliper slider could be sticking. Jack corners of car up an spin wheels. You will hear a very light scrapping sound if brakes a functioning properly. Scraping will be louder if a pad is indeed dragging. Same with the rears. Spin the wheel and listen. Also spin with e-brake engaged/not engaged to ensure that e-brake is not seizing.
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
Just curious as to why a person would buy a second vehicle from a dealer that they obviously don't trust. The first car died within a week. And the Yaris has a maintenance light on. Was this on at the dealer? Sounds like punishment to me.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
If your Yaris is an auto transmission, the extra dceleration you are feeling could be the trans changing down a gear. It will do this to provide engine braking, usually when going down a hil and applying the brakesl. This is easy to see on the versions with a tachometer, as the RPMs will increase.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
if that check engine light is a recent issue it could be something as simple as the gas cap wasnt tightened properly, if its on its sending a code that a code reader can pick up get yourself a code reader or have a garage read it for you.
Have Yaris will travel.. |
^ OP indicated Maintenance Light, not Check Engine.
i've never seen a maintenance required light on my Canadian 08 Yaris sedan, do American versions of the car come with a maintenance required light and a check engine light?
A little research and it appears some Yaris models do have a maintenance required light, heres how to turn it off= https://www.google.ca/search?site=&s....0.wTtjy79nHBQ
#13 | |
| Thinking about a Yaris and have some questions | yariska | New YARIS Purchase Forum | 7 | 02-22-2011 04:34 PM |
| FIRST TIME CAR BUYER! WANT YARIS! HAVE QUESTIONS!! | jBABEE91 | New YARIS Purchase Forum | 7 | 12-10-2010 12:28 PM |
| getting a yaris... questions... | ku-rei | New YARIS Purchase Forum | 8 | 10-12-2006 07:35 PM |
