![]() Drives: 2007 yaris Join Date: Jul 2016
Need some help and ideas
Hello i am new on here. I have a 2007 yaris sedan automatic. I have been having problems with it starting. It seems to only start when it wants. I have new battery and alternator was just tested. When it doesnt start it just clicks. I usually have to jiggle wires connected behind the pos terminal of the battery.then it starts. Sometimes it starts just fine. It doesnt start i would say about 1 in 10 times. Also one of my belts squeaks real loud when started. I had the serpentine belt replaced already. I jave remote start. When i ise the remote start in the morning the car starts squeaks then shuts off. Then it starts again by itself and squeaks then shuts off. Then starts again this time no squeak and stays on. What could any of this be? Any help or suggestions would be greatly apppreciated
#2 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
1. MAF sensor if its damaged..wires being burnt off or cut 2. check the battery cables too...did you tighten them down all the way..there is another bolt thats attached back of the battery cable.. some people are going to say alternator...but if it doesnt starts 1/10 then i dont think this is the alternator issue..something is not fully connected 😧😧😧😧😧😧 Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Check that your battery connections are tight, and not corroded. Clean them with a wire brush. Sounds like you have a bad connection. It could also be a bad starter, but that shouldn't be affected by wiggling wires.
Cheers. |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
I agree with CoryM it does seem like you battery terminals are slack or damaged. Also seems like you need a new serpentine belt.
