Old 08-23-2016, 08:59 AM   #1
dogsridewith
Drives: 2007 2-door hatchback
Cowl Top Ventilator Removal (Piece above brake fluid reservoir)
(re: 2007 HB)
Did search here and just found a pdf exploded view of the three parts of the cowl top ventilator and various clips. Seems the part over the brake/clutch fluid reservoir should remove by itself so you don't have to remove wipers to do simple maintenance. The front of his piece on mine lifts easily after squeezing the two obvious clamps, but the rear of the piece seems very stuck to the rear driver's side piece (with the holes for the wipers.) Thanks for any suggestion on removing this piece or the whole 3-piece Cowl Top Ventilator.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Anyone care to make a DIY on break flushing and bleeding? Hard_Yaris DIY / Maintenance / Service 19 05-04-2011 03:49 PM
