Old 08-30-2016, 03:49 PM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Irritating squeak
For the last few weeks my 08 sedan has developed an annoying high pitched squeak, seems to be coming from a suspension component,prevalent when traveling over bumpy roads.
My mechanic couldnt find the source and a complete oil undercoating didnt eliminate the squeak. any one else get the 230K squeak? if so what was it?
Have Yaris will travel..
Old 09-04-2016, 02:16 AM   #2
rabbito
rabbito's Avatar
my spring squeeks too...wd40 doesnt solve the issue...need new replacement...😏😏😏😏
Cosmetic: Toyota red emblem
Old 09-05-2016, 04:08 PM   #3
jambo101
jambo101's Avatar
I presume its where the spring contacts the body, i guess its something i'll just have to live with as its new car time come spring.
Old 09-06-2016, 01:18 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
When installing my Tein S Tech's, we made sure to cover the contact points in some good thick grease to avoid squeaking. Worked well, I don't hear any noise coming from them over speed bumps, driveway ramps, etc.
Shifting squeak unadilla66 DIY / Maintenance / Service 2 09-26-2015 12:52 PM
Breaks squeak, but only for the first five minutes? thebombman53 DIY / Maintenance / Service 4 11-26-2014 11:21 PM
Rear drums constant squeak??? Jdm18c DIY / Maintenance / Service 2 05-26-2012 07:10 PM
Squeak when braking The little red pill General Yaris / Vitz Discussion 2 04-09-2010 12:11 PM
Gearbox/diff squeak, poor engine braking Kiz DIY / Maintenance / Service 8 08-01-2009 10:35 AM
