Old 09-14-2016, 10:08 AM   #1
nisar
Drives: vitz2000
Starting problem
Vitz2000 wont start easily after a one day without starting
when it starts it sound slow and finally normal
nisar is offline   Reply With Quote
Old 09-15-2016, 12:21 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The idle air speed motor is probably clogged up. You'd need to take the throttle body off and clean it.
Old 09-27-2016, 03:32 PM   #3
Could be a number of things. Start with the above. Add in cleaning the terminals on your battery. Take a meter to the battery and check to see if you are indeed getting the full 12v's out of it. Cells do go bad in batteries over time, especially if you've let the battery run dead a few times and had to jump start the car. Many many many different things to check here so start with the obvious things first and anything that sucks air.
yaris hard starting when hot, fine when cold ianpog DIY / Maintenance / Service 11 08-12-2015 10:24 PM
problem with co-worker yaris, need opinion on what it could be. Adriaan DIY / Maintenance / Service 5 10-20-2014 07:39 AM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 03:24 AM
Warrany Service Problem? 2009Yaris General Yaris / Vitz Discussion 4 03-31-2011 05:56 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
