The Flying Tomato
Drives: 2009 Red Yaris Hatchback Join Date: Dec 2009
Hey Ya'll
So I have been baffled with this for quite some time. I have a 2009 base hatchback. I do not have keyless entry (whether it is installed or not is beyond me). When I first bought my Yaris, I would always have to manually lock/unlock my locks - not surprising for a base model haha. One day I started my car just like I would normally, and the driver and passenger doors automatically locked when I shifted out of park (wtf?!?!). I know there are sequences of events that can program locking/unlocking with a key fob, but I don't have one. I thought that maybe I accidentally programmed the car to do this. I played around with different sequences and somehow undid the feature. After that, my doors wouldn't automatically lock for a while. Two days ago, I ran into a similar occurrence. When I started the car, my driver's door locked (not passengers); I did not shift the Yaris out of park. Now I know the first occurrence wasn't a fluke and that there has to be a way to program lock/unlocking without a key fob. Anybody know how? Otherwise I think my car is possessed!
The Flying Tomato
I also do not have buttons in the car that can automatically lock the doors.
Only Happy When it Rains
Do you have power locks? Or power windows? I'd think more crossed/stripped wires than anything good.
Colin Chapman disciple |
The 09 Yaris did not have that as a feature of the OEM power locks / keyless entry, so I would bet that your Yaris has an aftermarket keyless entry system installed. Take a look under the dash, below the steering column, for the aftermarket module.
#5 | |
The Flying Tomato
It appears to me that the problem is controlled rather than intermittent, I just don't know how it was induced/started. If it was due to shorted/stripped wires, wouldn't I see it more as an intermittent issue in the beginning rather than it happening consistently all the time like I'm seeing right now? Thanks! I would be surprised if an aftermarket keyless entry system was installed. I bought the car new from the dealer with ~20 miles on it. When I installed foglights a few months back, I didn't come across any wires or assemblies that seemed out of place or any that appeared to be aftermarket. Do you know off-hand if the newer/older models have that as feature? If so, which ones? Thanks! |
#6 | |
I don't believe that any of the Yaris do it. I know for sure that 06-11 do not. You can also pop one of the door panels off to see if aftermarket door lock actuators have been installed.
#7 | |
The Flying Tomato
![]() I know this is for a 2007 and not a 2009, but it says that the door lock feature that I am experiencing is a customization parameter for the 2007 year. I suppose it's possible they kept that feature for the 2009 model. I'm not sure what it's referring to in the first column "Display (Item)." Any thoughts? |
The Flying Tomato
Actually, I'm re-reading the pdf, and it's talking about doors locking/unlocking through the door key cylinder and not through interfacing with starting the motor. I guess I'm still stuck haha
Exactly. I still think you have some aftermarket stuff in there. Dealers sometimes add keyless entry locally to try to increase the value or marketability of a car. Sometimes if the buyer doesn't want it they just don't give them the key fob, rather than removing the whole thing.
#10 | |
The Flying Tomato
#11 | |
#12 | |
![]() Drives: 2000 Land Cruiser & 2007 Yaris Join Date: Nov 2012
I have a 2007 Yaris with power windows and key less entry... I was wondering how can i activate this mode to unlock only the driver door with one push off the unlock button and the others with two pushes |
I am not aware of a way of doing it, other than by using the Toyota service tool.
Correct.
I just wish mine would honk the horn when I hit the lock button on my remote.
#17 | |
![]() Drives: 2007 Yaris Join Date: Sep 2011
I have had a dozen cars with remote entry, and this is the only one that does not give you a horn chirp when locking. I'm getting old and I'm too lazy to look back at the car to see if the if the lights blinked to confirm the "lock". |
#18 | |
| Tags |
| automatic lock sequence |
| Installation of original power windows and locks in Yaris | lantis | DIY / Maintenance / Service | 4 | 02-25-2012 02:38 PM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
| Power windows and locks on a 2009 3dr. | chilly79 | DIY / Maintenance / Service | 8 | 12-15-2010 01:55 PM |
| Should I buy an automatic? | ktoyo | New YARIS Purchase Forum | 40 | 06-23-2010 03:09 PM |
| Adding Automatic Locks | MrJester | DIY / Maintenance / Service | 15 | 06-08-2007 02:02 AM |
