![]() ![]() Drives: 2007 Yaris hatchback Join Date: Feb 2016
Alternator voltage
Hello hope someone can help me out what should be the normal voltage for the alternator on the Yaris? Because mine is showing 13.70 to 13.60 under load I haven't tested with 2000 rpm yet and when I hooked up a tester it says that is charging within normal range but not strong on the 14 volt I got the tester at harbor freight tools if someone is interested in picking one up dirt cheap, mark my question is should I replace it now or wait till the light starts to flicker if it even does?
P.s i found a alternator at a wreck yard on a 08 yaris sedan with 8000 miles on it |
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
13.7, 13.8 is fine, if it puts to much voltage it will boil the water out of your battery. If it was mine I would use it until it quit, I had a olds I had to replace the alternator every two years about 25,000 miles, but I've had other cars that the alternator lasted over 200,000 miles.
you have how many miles on the car now?
Voltage is normal. Test at 2-3K rpm |
Thanks for the replies I have 160000 miles vitz
I guess I have one of the good ones since is the original oem because I did my research and it appears there is an issue with the voltage regulator on the 07's with corrosion
Alternator
Having a spare alternator is not a bad idea.
