nick
Drives: 2007 yaris Join Date: Feb 2011
replace alternator 2007 yaris
how do you replace the alternator on 2007 yaris
nick
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
It mentions removing a right side engine under cover. Is this to perform the job from underneath the vehicle, on a lift? Can it also be performed by removing the front bumper? Or do you HAVE to remove the front bumper anyway? Or can it be done from the top?
Give Me Resonance
It can be done from the top without removing the front bumper, I know because I've done it and Ive also had to put on a serpentine belt on the side of the highway, fun stuff.
![]() (3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver |
As stated check out the stickied service manual and get familiar with that section. Understand how the wiring clips to the alt. so you don't break those. Be sure to understand where to apply force when tightening up the belt after replacement. That said I can have one off in 15 minutes from the hood opening.
^+1
Those are good points. Make very sure that you disconnect the battery before pulling the alternator wiring. The large gauge wire is directly connected to the battery with a larger fuse than you want to experience popping. Also, as mentioned you have to be very careful not to pry against the camshaft timing oil control valve.
yak
Drives: 2007 5 dr yaris Join Date: Jan 2009
G'day I know this is an old post but, the 14 mm bolt is extremely difficult to access from the top...what do you suggest for tools ??
I'm using 3/8 ratchet w/14mm six point socket but there isn't enough engagement for the ratchet to socket; it hits the idler pulley, no room for a regular extension ps I have removed the A/C line bracket as noted in the service manual cheers & thanx yak |
#9 | |
Have a ratchet wrench?
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 01:51 AM |
| What the Yaris community needs to take the Yaris to the next level | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 124 | 04-30-2009 03:03 PM |
| Florida Yaris Meet! 6/23/2007! | Sabretooth | Southeast | 13 | 06-05-2007 07:46 PM |
