Old 08-29-2009, 12:22 PM   #1
RedRide
RedRide's Avatar
My trim rings and center caps.....
Ok, the weather is nasty out there and I'm bored, So here's a pic of my trim rings and center caps.
I went with ABS chrome rings as was suggested.
I then added center caps that I got on e-Bay for $10 for all four.... brand new.
Old 08-29-2009, 08:55 PM   #2
Inspector14
Drives: 09 Yaris hatch, Meteor Metal
i have aluminum trim rings and they rattle up a storm. do yours rattle?
im thinking of center caps too, any suggestions?
Inspector14 is offline   Reply With Quote
Old 08-29-2009, 10:22 PM   #3
Liltoaster
Drives: 05 Echo H/B
Looks good, alot better then most setups! Now paint that steel wheel a crazy color and call it a day :)
Liltoaster is offline   Reply With Quote
Old 08-29-2009, 10:49 PM   #4
RedRide
RedRide's Avatar
Some on here said to get ABS chrome rings FTW and they were right.
Plastic wont bend for one thing.. The ones I got were from e-Bay and I'm very pleased with the quality. The don't rattle at all.
As far as center caps , there are a few options and it's really up to personal opinions.
I originally wanted the ones I got and got lucky when I got them.
Old 08-30-2009, 02:06 AM   #5
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
those center caps look great. Sent ya a PM!
Old 08-30-2009, 10:18 AM   #6
YAR1S
YAR1S's Avatar
:] I have them too but I have polished metal dust caps on mine.
-Jen <3
Old 08-30-2009, 10:25 AM   #7
Inspector14
i want to get center caps, but am apprehensive about size. os there a certain size we have to look for?
there are some on ebay that come off of a cressida, cant see the back of them so i dont know how they attach. they are big enough that they surround the lugs. is there a measurment to look for?
Old 08-30-2009, 01:43 PM   #8
RedRide
RedRide's Avatar
Center caps just snap into the center opening on the wheel much like a hub cap.
As fas as what will fit, I just do know that if is for a Tercel or Corolla, it will most likely fit.
Old 08-30-2009, 03:02 PM   #9
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Yeah, those give you a nice, clean look.
Old 09-18-2009, 12:45 PM   #10
lmwfy
Drives: 08 3dr Black
Exclamation Bent rim...
sorry to bump, but I'm concerned this bend on the wheel will affect a trim-ring placement..
thoughts?
suggestions to fix?
(sorry for horrible pic)
lmwfy is offline   Reply With Quote
Old 09-18-2009, 03:42 PM   #11
kimona
kimona's Avatar
Drives: 2014 White VITZ
Give it ago ans see if the trim ring sits flush. Otherwise... I see a big hammer in your future.
Old 09-18-2009, 04:58 PM   #12
YAR1S
YAR1S's Avatar
That more than likely wont affect the trim ring being on there.... they attach at the inner part of the lip not the outer part. The trim ring will probably even hide the bent lip.
-Jen <3
Old 09-25-2009, 07:25 PM   #13
lmwfy
I've had success in getting the rings on!
However,
Originally Posted by lmwfy View Post
Just got these:
Unfortunately, the tabs sit right outside of the wheel center..
Suggestions on a snug fit?
(already looking into double sided tape)
Old 03-12-2012, 09:51 PM   #14
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
where did you find those toyota symbol center caps? i can't find them anywhere....
yariSB86 is offline   Reply With Quote
Old 09-25-2009, 07:44 PM   #15
kimona
kimona's Avatar
lmwfy, PM RedRide and ask how his centre caps fit. They look to be the same as your caps.
Old 09-26-2009, 03:41 AM   #16
RedRide
RedRide's Avatar
Yes, they do look the same as mine.
I have no idea why they don't fit your steelies.
Mine fit perfectly.
Old 09-28-2009, 02:36 PM   #17
RedRide
RedRide's Avatar
OK I got around to taking a cap off to measure it and guess what...
I was wrong. The caps do not attatch to the inside of the hole but, on the outside of the hole lip. I guess I wasn't paying close attention whan I installed them in a hurry.
I'm sorry if I caused any confusion.
Anyway, the hole and caps mount measures about 2 and 3/16 "
Old 10-01-2009, 02:26 PM   #18
ace101081
Drives: 2009 Yaris 4d lb
This is a work in progress...still need to pick up trim rings. I am not a big chrome guy...probably will pick up some stainless steel and modify to give them more of a gunmetal look.
I picked up the same center caps a lot of people on this forum have...then had a little arts and crafts time and painted the logos to match the white of the car. Wanted them to pop a bit more.
ace101081 is offline   Reply With Quote
Hub Caps?? barryware Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-15-2007 11:34 AM
